Upper Control Arm Bushing Tool by Neiko |
texanrebel
Senior Member Joined: 13-June-2018 Location: Houston, Texas Status: Offline Points: 208 |
Posted: 30-June-2019 at 3:27PM |
Neiko Upper Control Arm Bushing Removal Tool Repair for Ford, GM & Chrysler (OTC-7068)Has anyone here used this? Just doing a little research....one of the reviews on Amazon stated it worked perfect on a Torino. $126.88 on Amazon...still hesitent to spend that much on a C clamp But if you feel it's a good deal / product please comment, or if one of the less expensive one's on the market work just as well. Thanks
1972 Montego GT
1977 Mercury Monarch 1988 Ford Thunderbird Turbo Coupe |
are you doing poly bushings? if so you don't need to remove the shells. those can be put in easily with a vise or C clamp. for steel shells i'd recommend a press... you can get one from harbor freight for less than that
texanrebel
yes poly bushings. Appreciate it!
1972 Montego GT
ok, leave the shells as they are just heat around them with a torch or even a hand held propane torch will work, they'll smoke some when it sounds like bacon frying push the old rubber out after it cools clean off any residue with sand paper until they are clean metal then grease the poly and push them in all the way
^^^How to Wound Yourself With a Drill!^^^
(Your Mileage May Vary...)
texanrebel
I used the drill method to remove the bushings from the rear sway bar. Took me "just a bit longer" than the video! But it worked...
1972 Montego GT
