  New Posts New Posts RSS Feed - vac lines
vac lines
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: vac lines
    Posted: 29-June-2014 at 10:10AM
can I do a way with all the vac lines and just hook dis to main vac port. It apears I have a duraspark 11 system as it has all kinds of ports.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 29-June-2014 at 10:34AM
As far as thermo-switches and related waste, yes, but...
Make sure the dist vac is hooked to ported vacuum. If your dist. vacuum has 2 ports, replace it with a single port version, and you may have to play with your timing setting to find the "sweet spot".
Duraspark ll works pretty good, and the ignition brain functions just fine independently without the vacuum switches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 29-June-2014 at 11:08AM
yes, what randy said, ported vacuum, readjust timing and idle Thumbs Up to find ported vacuum: find the one that has no vacuum at idle/then vacuum only when you open the throttle a bit
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 29-June-2014 at 12:06PM
Well I am not to versed in this area.Been reading all after noon.Was going to use vac. from manifold which goes to canaster first then to every were else.How many ports are there? Really miss my spell check.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 29-June-2014 at 1:37PM
look around the base of the carb for a small line, check for vacuum- no suck at idle, then bring the rpm's up about 100 or 200 you should feel suction then, if so then run a vacuum hose from there to your dist advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 29-June-2014 at 1:44PM
Brake Booster and transmission modulator valve get manifold vacuum. (ususlly a big tee at the rear of the manifold)
If you have an A/C car it uses manifold vacuum to control the heater. There should be a "coffee can" on your left inner fender that is a vacuum reservoir. (these usually fall out of their bracket and get stuck in the pocket by the hood hinge)
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 29-June-2014 at 3:18PM
Thats were mine is.Ok got it, if it don't rain tomorrow will try and see.
