Vent Cowl? |
mainemud ![]() New Member ![]() Joined: 11-September-2018 Location: Maine Status: Offline Points: 15 |
![]() ![]() ![]() ![]() ![]() Posted: 11-September-2018 at 1:37PM |
![]() ![]() Looking for what I believe is called the vent cowl / cover. Water is getting inside vent system while i'm doing other work. I'm new to finding a company that either makes these or perhaps OEM from a yard. Thanks all 70 fastback |
1970 Torino Fastback with 1972 Lincoln 460
Rockatansky ![]() Senior Member ![]() Joined: 30-July-2010 Location: On The Road Status: Offline Points: 4251 |
the cover / grills don't keep water out, if you're getting water into the vents you have a rust problem under the pine needle acorns and leaves. from new in 1970 there was a stand-off the separates air from water for the blower fan intake, in 2018 it probably looks more like this ![]() the putty schmoo was from when water started getting into the vents as you're describing, then the rest crumbled through around the stand-off hat and water started coming directly into the passenger compartment. big job to fix ![]() |
Appreciate the info. Fiberglass repair?
depends upon the level of repair / restoration and how long you need it to last? i used fiberglass, other have welded in metal. some have covered over the entire cowl air intake and sealed it so no water (or air) gets in anyway. i might be 'off' but i think i just remembered there are repair panels available for 70-71 cowls? Edited by Rockatansky - 11-September-2018 at 3:21PM |
here's what i found when i removed the top 1/2 of the cowl pillow, drivers side ![]() middle ![]() passenger side ![]() ![]() ![]() ![]() ![]() |
Incredible post! Thank you so very much! Your pictures are invaluable.
newmexguy ![]() Member ![]() ![]() Joined: 27-September-2012 Location: las Cruces Status: Offline Points: 143 |
Yes some awesome documentation. I have only seen One 70 - 71 in over a decade of u pull it yarding in El paso. A beat up four door. In hindsight should have taken more off it than the few bits I did remove.
Tweet
