Vin locations-72 Ranchero |
russosborne
Posted: 02-January-2020 at 11:04PM |
Besides the dash plate, and the label on the driver's side door opening below the door latch, where all would the vin's be located? Need to do some verification. Thanks, Russ
legend onirot
Senior Member METAL GOD Joined: 18-January-2009 Location: hattiesburg ms Status: Offline Points: 3038 |
dog tags under the dash should be the only other place
The engine and transmission is sometimes stamped with a partial VIN too. Lots of the parts are date stamped, like the frame, and body parts. They should be a little bit before the build date.
legend onirot
i forgot about those. thanks vince.
however, on my car, the engine block was stamped... but the transmission nor the frame was stamped anywhere. and i never saw it on any of the other parts.
i have yet to find a VIN on any of these frames
if you remove the dash top there's a tab off the cowl |
It seems only some cars had partial VINs stamped on the engine and transmission. So I am not surprised yours didn't have it on the trans. Lots didn't, mine for whatever reason had both. I should clarify, other than the dash, the body buck tags, and sometimes the engine and trans, I don't know of any other VIN locations. The frame is not VIN stamped. However, lots of parts are date stamped, like the frame, and other body parts. My frame has the date stamped into it in several locations. This date stamp should be within about 6 weeks before the cars build date. I too have never seen a frame or other body panels VIN stamped.
russosborne
Thanks, all. That explains it. I thought that these had the vin on the frames like GM's did around that time. No wonder I couldn't find it. Russ
VIN may also be stamped on the floor under the carpet, driver side sill area near the seat belt,
russosborne
Thanks.
Russ
