  New Posts New Posts RSS Feed - VIN place?
VIN place?
Anderslober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Topic: VIN place?
    Posted: 31-August-2019 at 1:09AM
QQ...do 72-73 Torino`s have the VIN in the dash just under the windshield on the left side??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2019 at 5:38AM
it's on a tab near center under the dash cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2019 at 6:46AM
there is a riveted tag on the metal dash cover on the drivers side front (removes with the dash pad)  there is a hidden vin tag like in the pic as well and a vin sticker in the drivers door jamb
 i have yet to find any on the frame of any of the 7 cars i've parted out and scrapped Shocked
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2019 at 7:10AM
and stamped into the door jamb ... ?
Will View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Will Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2019 at 12:40PM
How did you fix that cowl with what
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2019 at 1:45PM
disassemble, derust or replace with good metal
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2019 at 4:03PM
i went cheap & easy for a body that hardly deserved to be fixed.
rust converter and fiberglass Embarrassed
http://forum.grantorinosport.org/rockatanskys-72-ranchero_topic5563.html?KW=
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2019 at 6:47PM
i too when cheap... derust and 3 layers of fiberglass mat Wink
Regul8r 2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r 2 Quote  Post ReplyReply Direct Link To This Post Posted: 07-September-2019 at 7:14AM
yup only 4 places for the VIN on our cars as Johnny said.
printed on door jamb sticker, riveted tag on removable metal part of the dash pad and the last 6 digits(sequence #) are stamped on both of those tabs that are part of the original firewall stamped steel piece.
I have never seen ANY VIN numbers anywhere else on these cars, frames or even the engines.
Owner- www.CaNDeCustoms.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 07-September-2019 at 12:14PM
FWIW, my 72 had a partial VIN  the engine block and transmission. While there are no other VIN locations, there are many date stamped parts.  This includes the frame, body panels and other parts.These parts are usually within a few weeks of the car build date.
My car for example was built March 29th 1972 and most of the parts Ihave found with date stamps are March 1972. In fact many are within 10 days of the assembly date.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 07-September-2019 at 12:57PM
check your door jambs
