Vinyl roof/pitting repair and replacement |
Shuuga70
New Member Joined: 10-October-2015 Location: Denver Co Status: Offline Points: 2 |
Posted: 11-October-2015 at 10:10AM |
I have a 70 torino with a vinyl roof that was "bubbling" so I removed the vinyl and have some pitting and holes in the roof very small pinholes,about 5-10 total,I plan on reinstalling a vinyl roof,around the rear window in two top corner spots is in worse shape.my question is will the vinyl top cover any work I do,or should the top be in showroom shape to start. Thanks for any input
legend onirot
Senior Member METAL GOD Joined: 18-January-2009 Location: hattiesburg ms Status: Offline Points: 3038 |
my 73 gts's vinyl roof had some bubbling under it. i removed it completely on my restoration. that was my plan all along. the vinyl roof will hide some minor imperfections... minor. i was a little shocked at some of the imperfections that were hidden under mine.
those bubbles are RUST! you'll need to cut out the rust and replace it with new metal, or sand blast the rust back to good metal (both sides) or it will rust back later...then you are back to where you are now
Shuuga70
Next ques.? Was should I use wire wheel/sandpaper and bondo,or a sandblaster and welder?
