  New Posts New Posts RSS Feed - were to buy hood springs for our cars
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: were to buy hood springs for our cars
    Posted: 20-August-2016 at 12:58PM
All I could find were chev GM and generic no ford.
gnrlee01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gnrlee01 Quote  Post ReplyReply Direct Link To This Post Posted: 20-August-2016 at 2:11PM
i see a lot of hood springs for sale on ebay...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 20-August-2016 at 2:43PM
I don't think they exist in the aftermarket, and I couldn't find any Mustang or other car make springs that are close enough to use for our cars.  I ended up getting a set of springs used from another member.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 21-August-2016 at 4:50AM
try Green Sales
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 21-August-2016 at 12:49PM
How soon do you need a set? I'm pretty sure I have an extra set of hinges with springs in my garage.
2005 F-150 STX 4.6, 3.55 LSD
bambithegreat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bambithegreat Quote  Post ReplyReply Direct Link To This Post Posted: 22-August-2016 at 5:06AM
http://www.ebay.com/itm/1972-1973-1974-FORD-GRAN-TORINO-SPORT-RANCHERO-GT-SCOOPED-HOOD-HINGE-SPRING-RARE-/162175692248?hash=item25c26cadd8:g:fEQAAOSwezVWt60f&vxp=mtr
Post Options Post Options   Thanks (0) Thanks(0)   Quote gnrlee01 Quote  Post ReplyReply Direct Link To This Post Posted: 22-August-2016 at 1:48PM
has anyone ever heard of any kind of heat treatment to possibly revitalize the springs? i.e. like how certain heat treatments can harden or change the molecular structure of a piece of metal...
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 22-August-2016 at 2:23PM
oh i'm sure it could be done! but you may need to know the correct amount of temper and maybe the carbon count as well Confused
i have NOS springs for mine but when i had the hinges and springs ceramic coated... they stretched the springs to coat in between and also bake them, i'm afraid they lost a little temper ConfusedAngry
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 23-August-2016 at 12:48AM
Thats the thing. I have good ones on Rancharo.Have extra set but don't know if any good. Though just buy new ones,ha .
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 23-August-2016 at 2:11AM
With the number of 77-79 mid-size Fords and Mercurys out there that probably use the same springs (Ranchero, T-bird, LTD II, Cougar, etc), you'd think there would be enough demand for someone to manufacturer new springs.  Do 73-76 interchange as well?
Jeff
79 Ford Thunderbird w/ T-tops
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 23-August-2016 at 2:15AM
IIRC the NOS hinges i got were D7 so yeah i think they are all the same
mach1000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mach1000 Quote  Post ReplyReply Direct Link To This Post Posted: 23-August-2016 at 2:21PM
All should be the same 72 and on but the early years (72 and 73) used a flat style spring instead of round (edges of spring were flat) After 73 I believe they were all round. Mustangs 71-73 used two types of springs also. The cars with functional ram air plenums  (bolted under the hood) used the flat style rest used round. Apparently the flat style was a heavier load spring. Maybe Ford switched suppliers in 74 and they didn't need to use a different style spring or maybe they figured out how what spring load type worked for all. Not sure.
Maybe some of you guys can take a look at your spring and report back and your spring type and year.
Mach1000
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 24-August-2016 at 1:07AM
Green sales gave me the part no. for 79.He said more than one part no. one size does not fit all.
