  New Posts New Posts RSS Feed - What the heck is it!?
SilverSatllion05 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverSatllion05 Quote  Post ReplyReply Direct Link To This Post Topic: What the heck is it!?
    Posted: 07-September-2017 at 5:32AM
Hey guys,
Simple question... What the heck is this?
My engine caught fire over a year ago, and since then (after I had some work done), this has always been just kind of chillin'.  I don't know what it's to.  All my gauges work (well, my temp gauge hasn't worked since the fire, but grounding the charred connector spikes the gauge, so I think the sensor got fried), so I have no idea.  Neither does my mechanic know at a quick glance.
Please ignore the rust.  This thing has cowl rot up the ass, and the chemicals from the fire extinguisher mixed with rain getting though the hood scoop really messed up a lot.
Any ideas?  If it helps, I have a 302 and an after market two barrel carb, and it's a 1971 Torino 500.  I'm a novice and I learn as I got, so please cut me some slack if it's something easily identifiable.  :)
Edited by SilverSatllion05 - 07-September-2017 at 5:34AM
The Random Automotive
Website: http://www.therandomautomotive.com/
Twitter:https://twitter.com/therandomauto
Facebook: https://www.facebook.com/TheRandomAutomotive/
72GTS351CJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 07-September-2017 at 7:05AM
Looks like the connection for the hood light. Or possibly the a/c comp. Do you have air?
Edited by 72GTS351CJ - 07-September-2017 at 7:06AM
72GTS Clint Eastwood Special
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverSatllion05 Quote  Post ReplyReply Direct Link To This Post Posted: 07-September-2017 at 7:12AM
I didn't think about the hood light. As for the A/C, this car had factory A/C, but some previous owner thought it would be a good idea to half ass with a hacksaw. In short: no, I do not, but some parts remain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 07-September-2017 at 11:56AM
Sure looks like the A/C line.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 07-September-2017 at 12:49PM
I thought the same thing then I took a look at mine. My a/c wire runs along in the harness next to the valve cover. That connector shown is exactly like the one on my wire going to the hood light
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 07-September-2017 at 1:02PM
The wire that engages my A/C compressor clutch has that same connector, driver's side and is not in a loom. Has a little "sausage" in the wire as well. My hood light wiring is closer to the passenger side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 07-September-2017 at 1:27PM
Connect it to the hood light and put the a/c on. See if it lights up
Power Surge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 07-September-2017 at 1:30PM
I agree with Big Bird. Almost positive it's the AC wire. Mine is identical and comes off that same part of the harness.
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 07-September-2017 at 2:30PM
First pic is a/c compressor.....second pic is hood light...you be the judge
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 07-September-2017 at 6:13PM
test it with a test light... if it has power all the time it would be for the light? (my trunk light has a built-in mercury switch in the light socket...so it comes on when tilted) assuming the hood light is the same?
 if it's for the a/c it won't have power until the a/c is turned on
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverSatllion05 Quote  Post ReplyReply Direct Link To This Post Posted: 23-September-2017 at 3:51AM
Thanks for all the help guys.  I'll pop a light in it some day and see.  Sorry for getting back so late to all this.  I didn't get notified by email like I normally do.
