wheel fitment |
Hooter
New Member Joined: 04-October-2016 Location: Louisville, Ky Status: Offline Points: 18 |
Posted: 12-June-2017 at 1:58PM |
I have seen topic in here for wheel fitment but cant seem to find at this time thinking about 15x8 with 245-60-15 but don't know what offset most wheels I have found are 0 offset any suggestion thanks
Hooter
there's a thread on here somewhere.. but a few guys are running 235/60/15 on 15 x 8's so you should be ok
i have 15x 8 on the front ( can't remember the back spacing at the moment) but they fit fine |
Thanks(1)
Hooter
thanks for help will probably start checking for wheels and tire in a few weeks
Hooter
n2fordwagons
On a 15x8, you can run as large as a 275-60-15 on the rear. 245-60-15 on the front, or even a 255-60 won't be a problem.
Jeff
My T-Bird is closer to the Montego for wheelwells, but I have 255/70-15 on 8 1/2" wide U.S.Indy slots with 3" backspace and Lincoln Mark V rear springs. I could go quite a bit larger no problem.
I have 15 x 8 Magnum 500s with 4.5" backspacing front and rear. The fit with lots of room. I run 245/60-15 tires too.
