  New Posts New Posts RSS Feed - wheel fitment
wheel fitment
Hooter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hooter Quote  Post ReplyReply Direct Link To This Post Topic: wheel fitment
    Posted: 12-June-2017 at 1:58PM
I have seen topic in here for wheel fitment but cant seem to find at this time thinking about 15x8 with 245-60-15 but don't know what offset most wheels I have found are 0 offset any suggestion thanks
Hooter
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 12-June-2017 at 6:16PM
there's a thread on here somewhere.. but a few guys are running 235/60/15 on 15 x 8's so you should be ok
 i have 15x 8 on the front ( can't remember the back spacing at the moment) but they fit fine
Post Options Post Options   Thanks (1) Thanks(1)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 12-June-2017 at 7:43PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hooter Quote  Post ReplyReply Direct Link To This Post Posted: 12-June-2017 at 11:14PM
thanks for help will probably start checking for wheels and tire in a few weeks
Hooter
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 13-June-2017 at 12:29AM
On a 15x8, you can run as large as a 275-60-15 on the rear.  245-60-15 on the front, or even a 255-60 won't be a problem.
Jeff
79 Ford Thunderbird w/ T-tops
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 13-June-2017 at 9:31AM
My T-Bird is closer to the Montego for wheelwells, but I have 255/70-15 on 8 1/2" wide U.S.Indy slots with 3" backspace and Lincoln Mark V rear springs. I could go quite a bit larger no problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 13-June-2017 at 2:33PM
I have 15 x 8 Magnum 500s with 4.5" backspacing front and rear.  The fit with lots of room.  I run 245/60-15 tires too.
