  New Posts New Posts RSS Feed - Where are the casting #s on 351w
Md1976 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Md1976 Quote  Post ReplyReply Direct Link To This Post Topic: Where are the casting #s on 351w
    Posted: 18-August-2018 at 5:50PM
1976 gran torino, trying to see if engine is original to the car. Also having trouble getting temp gauge to work
7T9_Tbird View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7T9_Tbird Quote  Post ReplyReply Direct Link To This Post Posted: 19-August-2018 at 7:37AM
If memory serves, they're on the driver's side of the block, back by the rear of it.  As for the temp gauge, try grounding the sender wire to the block.  If it jumps up, it's a bad sender.  Otherwise, it's probably in the gauge, the printed circuit on the back of the gauge, or somewhere in the wiring.  I'd check the gauges after the ground test, then the wiring.  Hope this helps! Thumbs Up
John
79 Thunderbird Heritage
79 Thunderbird Town Landau
02 Ram 1500 Sport Quad Cab
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 19-August-2018 at 10:12AM
block cast codes can be deceptive as some codes run for multiple production years, the casting date will be more helpful. it's usually right below the block cast code near the starter. you'll see something like D4AE-BA that's the block code then below it the casting date code will look something like 6G26, then we can decode it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Md1976 Quote  Post ReplyReply Direct Link To This Post Posted: 19-August-2018 at 11:21AM
Would it be a matter of comparing the casting date to mfg date of the car? Thanks for info will hunt around for #'s
Post Options Post Options   Thanks (0) Thanks(0)   Quote Md1976 Quote  Post ReplyReply Direct Link To This Post Posted: 19-August-2018 at 11:23AM
Yes defiantly helps knowing how to test the sensor, don't like buying un necessary parts. Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-August-2018 at 12:58PM
what they said ^^^ olympia??? only olympia i know is in washington state!? if so i'm only about an hour south of you
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 19-August-2018 at 8:20PM
numbers matching guys usually consider cast dates within 1 - 1 1/2 months before the vehicle assy date to be correct
This page was generated in 0.105 seconds.
