  New Posts New Posts RSS Feed - Which Dashpot?
Which Dashpot?
KarlB View Drop Down
Brand New Member
Brand New Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote KarlB Quote  Post ReplyReply Direct Link To This Post Topic: Which Dashpot?
    Posted: 07-August-2017 at 11:29AM
I have been documenting my 72 Gran Torino in preparation for some restoration. It seems to be missing the Dash Pot. It is a California 302 2V. I am trying to use the ford parts book to id the correct dashpot . The book is a little confusing. I could be reading it totally wrong.
 These are the dashpots I found in the parts book : Sec 90.24, pg 3, "C8Az-9B549-A", and Sec 95, pg 21 Illust 9084," 9S514".
The photos on the net of C8AZ-9B549-A look like what I was expecting. 9S514 is totally different.
What should have been on the car? Will the C8AZ-9B549 work?
Thanks for your thoughts and ideas.
Karl
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 07-August-2017 at 1:00PM
What's a dashpot? Not meaning to be funny, just not sure what you're looking for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 07-August-2017 at 3:05PM
what i've always been told a dashpot was... the solenoid type thing that kicks the idle up a bit mounted to the corner of the carb
74 CORVETTE COUPE CUSTOM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 07-August-2017 at 3:07PM
actually i'll have to check these parts torino's i bought should have them as they are all calif. cars
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 08-August-2017 at 10:50AM
Oh, the anti-stall kicker...
Never heard it called a dashpot, is the one you need electric or vacuum?
jversch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jversch Quote  Post ReplyReply Direct Link To This Post Posted: 08-August-2017 at 1:58PM
That works with the AC also I think . Bumps up the idle so it don't stall j
Jerry VerSchneider
Brand New Member
Brand New Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote KarlB Quote  Post ReplyReply Direct Link To This Post Posted: 09-August-2017 at 2:23AM
The Ford Parts Book call it the "Dashpot Assy. (carb)" group 9B549. So that is what I called it. Just trying to be correct.
The car has AC. My problem is the Ford parts books seems to identify two different dash pots.
One maybe vacuum operated. The Ford description is somewhat vague so I am not sure. The other part identified has the standard spring, based on the illustration.
The standard spring version seems to be available. I haven't been able to find a vacuum operated dash pot for the car.
Going with the standard spring version maybe the way to go. For those of you with a California car let me know what you have on yours. Note the 351, per the book, is different then the 302.
This is just another one of those Ford mysteries.
Thanks
Karl  Smile
