which oil pan for 460 in Torino Sport? |
samplesdm ![]() New Member ![]() ![]() Joined: 24-March-2018 Location: Butte MT Status: Offline Points: 11 |
![]() ![]() ![]() ![]() ![]() Posted: 24-May-2018 at 8:43AM |
Hi All. i found the correct mounts that i need, but it seems that the oil pan is too big. The 460 came out of a '78 camper special. When i lower the engine down, the oil pan sits on the cross member. It sounds like I need a front sump pan. I've seen several of them on Amazon, will any of them work? Also, will i have to change the pump pick up tube, or will it be in the right place and be the right length. How about the dipstick?
Thank you! -Dennis |
I forgot to mention, the car originally had the 351C in it.
qcode72 ![]() Member ![]() Joined: 18-October-2013 Location: greenville,pa Status: Offline Points: 58 |
You will need the front sump pan and pickup.
72FordGTS ![]() Admin Group ![]() ![]() GTS.org Admin Joined: 06-September-2005 Location: Ontario, Canada Status: Offline Points: 4227 |
Like other's said you need a front sump, the truck pan won't work. You can still get a stock replacement front sump from a parts store. Summit has this once for a pretty cheap price: |
GranTorinoMan ![]() Senior Member ![]() Joined: 14-August-2005 Location: Canada Status: Offline Points: 919 |
I bought this Canton pan for my 429 in my 72 GTS https://www.cantonracingproducts.com/product/15-750/15-750----BBF-DEEP-FRONT-SUMP-STREET-PAN/ Edited by GranTorinoMan - 16-July-2018 at 5:12PM |
Tweet
