  New Posts New Posts RSS Feed - which oil pan for 460 in Torino Sport?
samplesdm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote samplesdm Quote  Post ReplyReply Direct Link To This Post Topic: which oil pan for 460 in Torino Sport?
    Posted: 24-May-2018 at 8:43AM
Hi All. i found the correct mounts that i need, but it seems that the oil pan is too big. The 460 came out of a '78 camper special. When i lower the engine down, the oil pan sits on the cross member. It sounds like I need a front sump pan. I've seen several of them on Amazon, will any of them work? Also, will i have to change the pump pick up tube, or will it be in the right place and be the right length. How about the dipstick?
Thank you!
-Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote samplesdm Quote  Post ReplyReply Direct Link To This Post Posted: 24-May-2018 at 8:44AM
I forgot to mention, the car originally had the 351C in it.
qcode72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote qcode72 Quote  Post ReplyReply Direct Link To This Post Posted: 24-May-2018 at 12:50PM
You will need the front sump pan and pickup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 24-May-2018 at 2:44PM
Like other's said you need a front sump, the truck pan won't work. You can still get a stock replacement front sump from a parts store.
Summit has this once for a pretty cheap price:
