  New Posts New Posts RSS Feed - Wiper Arm removal
Wiper Arm removal
Post Options Post Options   Thanks (0) Thanks(0)   Quote changinlatitudes Quote  Post ReplyReply Direct Link To This Post Topic: Wiper Arm removal
    Posted: 25-April-2018 at 8:32AM
Any tips on how to remove them without:
1. Buying the special tool
2. destroying the arms or the whaz-it-called...the spindle, I guess.
Thanks,
Matt
1972 Montego MX
2003 Mercury Marauder 300A
2015 Honda Civic Coupe
2016 Ford Fusion Titanium
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2018 at 11:40AM
Lift the wiper arm so it "breaks" at the pivot that attaches to the wiper's spindle, look at the bottom of the arm next to the pivot, there is a slip-shoe clip that needs to move outward-away from the center of the arm. Once the clip has moved outward, allow the wiper arm to relax against the clip, you should now be able to pull upward and remove the wiper arm assembly from the wiper arm spindle. Hopefully I 'splained that correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2018 at 12:12PM
^^^THIS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 26-April-2018 at 2:53PM
once the lock clip is opened, you can usually jiggle it until it comes off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote changinlatitudes Quote  Post ReplyReply Direct Link To This Post Posted: 27-April-2018 at 2:08AM
Cool. Thanks dudes!
Matt
1972 Montego MX
This page was generated in 0.093 seconds.
