  New Posts New Posts RSS Feed - Wiper Blade Replacement
78FordLtd2 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote 78FordLtd2 Quote  Post ReplyReply Direct Link To This Post Topic: Wiper Blade Replacement
    Posted: 08-August-2021 at 5:10PM
If you are looking for the "old" style of wiper blade assembly for your hidden windshield wipers, they are still available. These are the factory low profile pin type blades that retracted below the hood when parked (turned off). They can be ordered through Classic Industries and are correct for 70-81 Camaro/Firebird and 71-73 Mustang/Cougar.
Part# F-307 OER (18 inches long, black with rubber blade).
These will fit also fit 72-79 Torino/Montego/Ranchero. They are not cheap...not anymore ($26 ea plus taxes in Canada).
Best about these is they are factory correct and will NOT catch or get stuck under the hood when turning on or off...saving your paint.  :)
Post Options Post Options   Thanks (1) Thanks(1)   Quote 78FordLtd2 Quote  Post ReplyReply Direct Link To This Post Posted: 08-August-2021 at 5:14PM
How it looks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 09-August-2021 at 9:04AM
Thanks for the information.  I was able to get an OEM style set from Rock Auto on clearance a few years ago.  I am not sure if they still stock them, but they were very cheap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 06-January-2022 at 4:38PM
Same here, had good luck with Rockauto on wipers. When I got a second new windshield installed, after the glass shop fiasco breaking my glass, I got new wipers.
