  New Posts New Posts RSS Feed - Wiper Motor / Switch / Wiring Diagram
Del Griffith View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Del Griffith Quote  Post ReplyReply Direct Link To This Post Topic: Wiper Motor / Switch / Wiring Diagram
    Posted: 02-December-2019 at 3:33AM
The wipers are not working - looking for ideas.  Below is what I tried thus far:
-Turn on wipers and check power at harness motor connector (red/lack) - no voltage
-Unplug switch harness behind dash, and test with an old switch of unknown status (no joy - actually worse as this switch will not even operate pump, as original does).
This leads me to ask if anyone has suggestions for debug, and where can I get a wiring harness diagram?
'69 Torino 2 -Door Coupe
Post Options Post Options   Thanks (0) Thanks(0)   Quote schufitz Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2019 at 11:03AM
Radio dead too? Same fuse (#6) as wiper & b/u lights.  Maybe check that.  If fuse good, not too sure, maybe radio short (?).  If you can get it power, make sure it has a good ground to the brass ribbon.  The motor is grounded via mounting bolts.  I had mine off to paint it and didn't work after re-installation, even though I thought I had wire brushed the contact areas for that mounting screw pretty good.  I ended up putting on a large washer to contact the ribbon and it now works.  Don't notice it too much unless looking for it.
Below is a page from the 1969 wiring diagram.  Hopefully you can zoom in on.  If not, PM me e-mail and I can send to you.  Said file was too large to attach.  Good luck in troubleshooting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Del Griffith Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2019 at 11:46AM
schufitz,
Thanks for details.
The fuse must be good then becasue the radio powers on but will not tune in any station - just static (even on Accessory).
I sent email for diagram as it looks like I may be able to ohm out the switch off the pic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2019 at 12:53PM
probably the antenna is bad... if it uses the same antennae as the 72-79 cars let me know i have several good oem ones
Post Options Post Options   Thanks (0) Thanks(0)   Quote Del Griffith Quote  Post ReplyReply Direct Link To This Post Posted: 03-December-2019 at 1:48AM
CJ - good idea, wonder if there's a way to test it first?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 03-December-2019 at 3:40AM
continuity with an ohm meter center pin to mast and outer sleeve to ant. base should be continuity on both , but not between the two Wink
This page was generated in 0.046 seconds.
