  New Posts New Posts RSS Feed - Yellow Top Coils
Yellow Top Coils
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Topic: Yellow Top Coils
    Posted: 31-May-2015 at 4:05AM
My car is still running the OEM Motorcraft Yellow Top coil.  I'd like to replace it, but from reading online it seems most of the Repro Yellow Tops are junk or for people who don't actually drive their cars.
Is there anyway to get a good quality yellow top coil for me car?  Or I am stuck with an aftermarket coil that I will have to paint?  I want a good quality coil that won't leave me stranded, but I prefer to try and keep my car as OEM appearing as possible.
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 31-May-2015 at 10:42AM
We know a guy who can paint it for you!
Sorry, just HAD to do that!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 04-June-2015 at 7:48AM
Anyone?  I know there are guys on here who have done factory correct restorations, what are you running for coils?
It's not just the colour that's different, the Ford coils have the terminals in a different position than the aftermarket coils.
Does anyone know what the stock resistance is for a factory coil?  I may end up just getting a black one from Pertronix and painting the top.  Pertronix wants to know what the resistance for the stock coil should be to suggest the correct one.
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Posted: 04-June-2015 at 8:54AM
If I remember correctly, it was yellow that he "painted" it, too.
That was a fine looking coil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 04-June-2015 at 9:10AM
I must be missing some inside joke??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 04-June-2015 at 10:13AM
Sorry, yes inside joke.
As for the info, I don't have the info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 06-June-2015 at 2:04PM
I found the following through an internet search on a Ford FE Forum:
1.40-1.54 ohms primary @ 75F and 7600-8800 ohms secondary @ 75F
Does this sound right for our cars too?
The main reason I am concerned with the coil is I don't want to mess up my factory tach.  So I just want to make sure I don't put too much current through the tach.
foote500 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 06-June-2015 at 2:10PM
I think I got the joKe... Emphasis on the "K"...
Edited by foote500 - 06-June-2015 at 2:11PM
Marc
German Shepherd Rescue
1967 Ford Fairlane 500, 390
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 06-June-2015 at 2:49PM
I am not saying that the specifications that you posted above are wrong, but usually the specifications for a new replacement factory original type of ignition coil, for your car and engine combination would be close to:
Inductance (mH): 6.6
Minimum Primary Resistance Range: 1.50 Ohms
Minimum Secondary Resistance Range: 11,000 Ohms
For a few dollars more than the coil listed above, you could get the more expensive/higher quality original equipment type coil with these specifications:
Minimum Secondary Resistance Range: 10,000 Ohms
Edited by dave302 - 06-June-2015 at 4:58PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 07-June-2015 at 2:39PM
Hey Dave,
I am not sure if those specs are accurate or not.  What coils are your listed specs from?
If that's the case Pertronix makes a coil with 1.5 ohms Primary, 9.0K ohms secondary and 6.4 mH.  So this sounds like it should work for my car?
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 07-June-2015 at 4:31PM
Alright, I am not that great at all the numbers-if I wanted to buy a coil that would most likely work in my mostly (with the exception of Pertronix unit in the distributor) stock car, where and what what should I buy? I am looking at a NOS coil DGC-13 D27Z-12029-A, but I can see on the coil it says for use with external resistor... I have no clue, and all the talk about messing up the tach, again I have no clue, what can I buy that I can just switch out, monkey see monkey do...
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 08-June-2015 at 8:19AM
Marc,
if you car still has the resistor wire in place, then it is externally resisted.  Measure the voltage on the positive side of the coil while the car is running, it should be about 8 volts or so if the resistor wire is in place.  If it was been bypassed with will be around 13 volts.
Where are you finding NOS yellow tops? I'd be interested?  My only issue is, it's a crap shoot on how well and how long a NOS coil will work.  Failing that, I think you'd be stuck buying a replacement coil and painting the top yellow.  The terminals won't be in the correct location, but only someone looking very closely would notice that.  Apparently Cub Cadet yellow or John Deere yellow are pretty good matches.
Edited by 72FordGTS - 08-June-2015 at 8:20AM
