  New Posts New Posts RSS Feed - 15x7 5x5.5 bolt pattern
weaverT1971 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote weaverT1971 Quote  Post ReplyReply Direct Link To This Post Topic: 15x7 5x5.5 bolt pattern
    Posted: 31-August-2014 at 3:09PM
I'm looking at some Keystone Klassics that a guy had on his  54 Ford F-100.....will these fit my 71 torino?
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 3:21PM
The 15X7 rims will fit a torino, but the 5x5.5 bolt pattern will not fit. You need rims that have a 5X4.5 bolt pattern for your car.
Edited by dave302 - 31-August-2014 at 3:22PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote weaverT1971 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 3:23PM
I was afraid of that damn it!!!!!brand new tires too......I knew it was to good to be true.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 3:25PM
Unless the previous owner of your car had installed all of the parts to change your cars wheels to a 5X5.5 bolt pattern. I doubt that he did that though.
Edited by dave302 - 31-August-2014 at 3:27PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 3:31PM
Measure the center to center distance between two studs directly across the hub from each other.
5lugs
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 3:33PM
If your wheels are 5X4.5" then, the distance between the two studs (from the center of one stud to center of the other stud) will be 4.5 inches.
Edited by dave302 - 31-August-2014 at 3:35PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote weaverT1971 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 3:35PM
Yep.....that's what they are I just measured them.....maybe he didn't measure right? I could only be so lucky.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 3:37PM
Maybe, it might be possible... but i am not sure. You might want to ask him to measure them for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 3:40PM
What pattern are the wheels? Is the 54 ford truck still on a 54 ford truck suspension?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 3:44PM
I am almost 100% positive that a '54 ford f-100 has a 5X5.5 bolt pattern. Unless someone had changed the bolt pattern to a 5X4.5 bolt pattern.
Post Options Post Options   Thanks (0) Thanks(0)   Quote weaverT1971 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 3:47PM
I believe so
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 3:54PM
Back in the 80s, popular "upgrades" to those trucks involved Volare/Aspen K-member/suspension, and Ford 9" rears.
Volare/Aspen swap was easy, cheap, and gave you independent front suspension, power steering, disc brakes all in one package, with anti-dive and ackerman already worked out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 4:00PM
The 15X7 keystone klassics are only availabe in three different bolt patterns: The 5X4.5", the 5X4.75" and the 5X5.5" bolt patterns.
Edited by dave302 - 31-August-2014 at 4:10PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 4:02PM
It could also be possible that the suspension could have been changed on this f-100 (like Big Bird has suggested).
Edited by dave302 - 31-August-2014 at 4:11PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 4:07PM
The 15X7 keystone klassics also have a rear spacing of 3-3/4" and they have a -6mm offset.
Post Options Post Options   Thanks (0) Thanks(0)   Quote weaverT1971 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 4:09PM
so he may have mis measured them? And they may still work?
Edited by weaverT1971 - 31-August-2014 at 4:12PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 4:15PM
They do make 5X5.5" keystone klassics also, so the seller may be right/correct when he says that he has 5X5.5 bolt pattern wheels.
Edited by dave302 - 31-August-2014 at 4:15PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote weaverT1971 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 4:17PM
So pretty much any 5x4.5 rim will fit my car thought right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 4:20PM
The 5X4.5" rims will fit on your car, but sometimes you also have to watch the sizes of the "backspacing" and "offset" sizes of the rims too.
Edited by dave302 - 31-August-2014 at 4:23PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote weaverT1971 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 4:24PM
http://buffalo.craigslist.org/pts/4599808438.html
If those other ones dont pan out I'm looking at these. The guy had them on a 72 or 73 Dart/Duster
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 4:30PM
He is advertising them as 5X4.5 bolt pattern, so they will fit your car. The other members might be able to give you more information about if the tire sizes are okay too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 4:32PM
There is a good thread on this tire and rim size subject, to see the thread Click Here.
Grantorinosport351 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grantorinosport351 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 4:35PM
if not, you can buy adapters?
~Bryan
72 gts h-code (formal roof)
67falcon
04 f250 ''the great white''
Post Options Post Options   Thanks (0) Thanks(0)   Quote weaverT1971 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 4:40PM
Yeah, I've been checking that thread out. It seems they will fit as long as the back spacing will work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote weaverT1971 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 4:43PM
I don't know about those....heard they weren't very safe
Edited by weaverT1971 - 31-August-2014 at 4:46PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2014 at 4:51PM
yes, they do sell shims to increase the backspacing on rims, but you might not need them for these rims. But you still have to watch the offset sizes on some rims also (but the offset size might be okay on these rims too). all of the information should be in the link to the thread that i had posted above.
Yes, they sell shims/adapters to increase the backspacing sizes.
I am not sure, but maybe one of the other members will know for sure.
Edited by dave302 - 31-August-2014 at 6:36PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote weaverT1971 Quote  Post ReplyReply Direct Link To This Post Posted: 06-September-2014 at 7:50AM
OK everyone, I bought the rims in the link from craigslist.....But here's the issue, what lugs do I get for these? I mean I know the lugs need to be 1/2 20's but what is up with the slots milled in the holes and where do I get washers like that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 06-September-2014 at 11:15AM
If the holes are slotted, it's a unilug wheel. The Lugnuts will be a shaft design that goes inside the slots and use a washer at the wheel with an offset hole that locates the wheel and lug nut
. (can't explain better, but once you see one, you will understand)
Post Options Post Options   Thanks (0) Thanks(0)   Quote weaverT1971 Quote  Post ReplyReply Direct Link To This Post Posted: 06-September-2014 at 1:04PM
Thanks! On my SST's the washer is offset so I think it'll work but I'll have to get shorter shaft lugs.
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 06-September-2014 at 2:40PM
The lug nut style that you need is typically called "mag seat" or "mag style".  The shaft part comes in different lengths depending on the thickness of your wheel.
Jeff
72 base Torino (modified)
72 Gran Torino Squire
This page was generated in 0.129 seconds.
