  New Posts New Posts RSS Feed - 1968 Torino Factory AIr Wiring
ptac85 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ptac85 Quote  Post ReplyReply Direct Link To This Post Topic: 1968 Torino Factory AIr Wiring
    Posted: 15-November-2021 at 8:39AM
 Does anyone have a sketch of how the wiring should be on a 1968 torinos air conditioning?
tp
Post Options Post Options   Thanks (0) Thanks(0)   Quote schufitz Quote  Post ReplyReply Direct Link To This Post Posted: 15-November-2021 at 10:38AM
Here is a page from the '69 electrical diagram manual.  I can't say for certain they are the same, but suspect they would be. Ford did change the design of water valve on the cowl, either later in the '68 run or for '69.
 The clutch control switch is a small round plastic part that attaches to the heater valve (along with small vac hoses that go back through the firewall to the selector switch on dash).
Old style valve
Edited by schufitz - 15-November-2021 at 11:08AM
