  New Posts New Posts RSS Feed - 1968 torino rear end swap
Spencer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spencer Quote  Post ReplyReply Direct Link To This Post Topic: 1968 torino rear end swap
    Posted: 27-April-2023 at 12:12PM
I'm looking into swapping out everything in the rear end to a 9" with disk breaks and a limited slip differential
I'm thinking of buying a new rear axel what do you guys think
8k40f24310 is the Vin if that helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spencer Quote  Post ReplyReply Direct Link To This Post Posted: 30-April-2023 at 5:13AM
Will a mustang rear end fit? If not what rear end out of what car would that is easy to find
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 30-April-2023 at 12:23PM
 not sure but youll need to measure center to center on you spring perches as weel as overall width or at least backing plate to backing plateWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spencer Quote  Post ReplyReply Direct Link To This Post Posted: 01-May-2023 at 2:11AM
Thanks John that's what I needed to know
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spencer Quote  Post ReplyReply Direct Link To This Post Posted: 05-May-2023 at 3:30AM
So I measured middle middle to middle on the leaf spring purch  and it's 44" 1/2" and backing plate is 52" does anyone have any suggestions on good rear axle swaps with lsd and disk breaks
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 05-May-2023 at 7:38AM
 i'll measure the original rearend out of my mustang, see if its the same?....
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 07-May-2023 at 12:43PM
 i measured my 68 8" rearend from my mustang... 43 1/4" center pin to center pin of the springs, 52" backing to backing. i believe mustangs are the same 65-70? most seemed to have 8" but i believe the BB cars 390-428 probably had a 9" S code and R code cars?
RacerJames View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RacerJames Quote  Post ReplyReply Direct Link To This Post Posted: 08-May-2023 at 7:31AM
'73 Torino Stock Car
'71 Mustang Stock Car
351C powered
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spencer Quote  Post ReplyReply Direct Link To This Post Posted: 17-May-2023 at 1:59PM
So the mustang is the same length but the spring is different would I be able to move the spring placement to ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Spencer Quote  Post ReplyReply Direct Link To This Post Posted: 17-May-2023 at 2:03PM
And 61.25 is the number for my year on your chart is that backing plate to backing plate or over all width?
Post Options Post Options   Thanks (0) Thanks(0)   Quote RacerJames Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2023 at 4:38AM
Spencer, there are two dimensions shown, one is measured from the axle wheel mounting surfaces and the other is spring perch location. A good welder/fabricator can relocate spring perches easily. the wheel mounting surface distances are not easily changed.
Be aware that most dimensions on the internet are flange to flange, meaning where the backing plate meets the housing. This isn't as helpful when one is trying to fit wheels under fenders, because the distance from the axle and the housing flange varies quite a bit.
351C powered
