  New Posts New Posts RSS Feed - 1969 428CJ R CODE CARB CONNECTIONS
ELT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ELT Quote  Post ReplyReply Direct Link To This Post Topic: 1969 428CJ R CODE CARB CONNECTIONS
    Posted: 08-January-2025 at 1:03PM
Hi, Happy new year everyone! I just got the original model 4150 Holley carb for my 69 C6 428CJ R Code. If someone has an original of the same, would you mind replying with pics of the throttle linkage and the exhaust manifold to choke set up? I would really appreciate it as I want to hook it up correctly. THANK YOU! Ed
Thanks,Ed
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 09-January-2025 at 9:52AM
I don't have pictures, but these parts diagrams should help.  The choke diagram shows 1966 and 1967, but at the bottom it is listed for all 1966-70 390/428s.  This is the diagram that comes up when I search for 1969 Torino 428.
ELT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ELT Quote  Post ReplyReply Direct Link To This Post Posted: 10-January-2025 at 1:10PM
Very helpful. Thank you!
Thanks,Ed
ELT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ELT Quote  Post ReplyReply Direct Link To This Post Posted: 17-January-2025 at 2:05AM
I just ran the metal fuel line down to the pump. 69 428CJ. It is very close or slightly touching the lower radiator hose. Pics show it is routed correctly. I assume they are all that way but it is a heat concern? Thanks, Ed
Thanks,Ed
ELT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ELT Quote  Post ReplyReply Direct Link To This Post Posted: 17-April-2025 at 2:01PM
It was the wrong pump. I replaced it. All good now. Still need the correct dashpot and bracket for the original 4150 double pumper carb. If anyone has for sale please let me know. Thanks!!
Thanks,Ed
This page was generated in 0.144 seconds.
