  New Posts New Posts RSS Feed - 1969 Equalizer Bar for 351W Tech Question
StuartB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StuartB Quote  Post ReplyReply Direct Link To This Post Topic: 1969 Equalizer Bar for 351W Tech Question
    Posted: 03-January-2025 at 1:56AM
Hello all,
Hoping someone can assist. I'm converting my 390 4-speed car to a 351W and need a clutch equalizer bar (z-bar). This seems to be a specific 1969-only part for the Torino line and doesn't appear to be reproduced. Is there a similar Torino or Mustang z-bar available that will fit (even with modification) this application?
thanks,
Stuart
Stuart
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 03-January-2025 at 5:01AM
what have you found out so far, is the 390 Z bar too long or too short?
Post Options Post Options   Thanks (0) Thanks(0)   Quote StuartB Quote  Post ReplyReply Direct Link To This Post Posted: 04-February-2025 at 3:16PM
The 390 setup won't work at all with a 351W, different dimensions and mounting points between the engine and frame. I was fortunate enough to get a complete setup from Perogie Enteprises.
Stuart
Stuart
