  New Posts New Posts RSS Feed - 1969 Ford Cobra
1969 Ford Cobra
blitzkrull View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote blitzkrull Quote  Post ReplyReply Direct Link To This Post Topic: 1969 Ford Cobra
    Posted: 19-April-2024 at 2:10PM
My ‘69 Cobra has its numbers matching 428CJ and C6 tranny. The motor was rebuilt in ‘03 with Edelbrock aluminum intake, heads, water pump and a 750CFM carb. Since I bought it, my son and I have replaced the fuel pump, lower control arms, upper ball joints, shocks, alternator, coil and added a new Progression Ignition distributor; plus minor repairs inside. Also had the power steering valve and gear box rebuilt. Now I enjoy driving it on weekends and fixing little things as they need it.
Edited by blitzkrull - 19-April-2024 at 2:17PM
Wixbullitt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wixbullitt Quote  Post ReplyReply Direct Link To This Post Posted: 20-April-2024 at 1:16AM
Very nice car!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 20-April-2024 at 1:47AM
Wow, that is a very sharp Torino! What gears are you running? It must move out nicely with the aluminum heads on the 428. Is it a stock cam?
Post Options Post Options   Thanks (0) Thanks(0)   Quote blitzkrull Quote  Post ReplyReply Direct Link To This Post Posted: 20-April-2024 at 2:27AM
Thanks! It’s got a 3.5:1 Detroit Locker rear end and they put a Lunati cam in when they rebuilt the engine. It scoots along pretty good.
Kelly K
1969 Ford Cobra 428
Post Options Post Options   Thanks (0) Thanks(0)   Quote blitzkrull Quote  Post ReplyReply Direct Link To This Post Posted: 20-April-2024 at 3:07AM
Appreciate it. I read your story on your 72 Torino. That’s a nice job you did on it. I like that it’s an understated, “old lady” base-model body, but everything else is the guts from the Michigan GTS. I’m a big fan of sleepers. Yours isn’t quite a sleeper, per se, but I bet most folks don’t know what they’re rolling up on when they see it. :)
Kelly K
1969 Ford Cobra 428
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wixbullitt Quote  Post ReplyReply Direct Link To This Post Posted: 20-April-2024 at 3:44AM
Thanks Blitzkrull, it’s a lot of fun and a great conversation piece everywhere I go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote schufitz Quote  Post ReplyReply Direct Link To This Post Posted: 21-April-2024 at 3:45AM
Nice Cobra!  How was changing out the front suspension parts?  I've got the parts to upgrade my '69 GT, but the springs give me pause to change myself.  What spring compressor did you use?  Thx.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 21-April-2024 at 5:57AM
Cool!  Post some pics of the engine when you have a chance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote blitzkrull Quote  Post ReplyReply Direct Link To This Post Posted: 21-April-2024 at 12:59PM
I had the same concern, so I took it to a friend who has a shop. He recommended just doing the upper ball joint and not the whole control arm, so we wouldn’t have to tear everything apart. So, we did that and then the lower control arm which was easier.
I compressed the spring on an old Monte Carlo and was terrified the whole time, so I don’t blame you for being concerned. I’ve seen a few videos of them popping…
Kelly K
1969 Ford Cobra 428
Post Options Post Options   Thanks (0) Thanks(0)   Quote blitzkrull Quote  Post ReplyReply Direct Link To This Post Posted: 21-April-2024 at 1:22PM
Engine Pic:
This weekend, we put in new headlights (including amber hi-beams) and fixed the fuel tank vent hose with info I got from a post on this forum, so thanks for that!
Kelly K
1969 Ford Cobra 428
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 22-April-2024 at 3:09AM
Looks great!
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 27-April-2024 at 12:56PM
Really nice car
