1969 Torino Shock tower measurements |
Post Reply
| Author | |
Josh1969
Joined: 10-November-2019 Location: NC Status: Offline Points: 3 |
Quote Reply
Topic: 1969 Torino Shock tower measurementsPosted: 10-November-2019 at 1:13AM |
Hey guys new to this forum. I am having issues with my 69. The top control arm is shimmed out as far as it will go and the bottom is pulled in the same. My camber is still way outside of spec. Does anyone have the factory measurements on the shock tower placement so I can start trouble shooting what's causing my issue? Probably need inside skirt to skirt and the distance between the shock towers. Any help would be appreciated.
schufitz
Joined: 23-February-2014 Location: Hammond IN Status: Offline Points: 266 |
Quote Reply
Posted: 10-November-2019 at 2:11AM |
Attached is a pic from the '69 shop manual that may have what you're looking for. I've got a '69 and could take some measurements if needed.
Josh1969
Quote Reply
Posted: 10-November-2019 at 4:14AM |
Thank you Brother! Thats exactly what I needed!
Josh1969
Quote Reply
Posted: 16-November-2019 at 8:09AM |
well my baby is going to a frame machine on the 2nd of December.....no clue what this is going to cost! Based on the dimension sheet you sent me its not good. Someone went to a lot of trouble to hide the damage without actually fixing it...Thanks again
Joined: 05-October-2013 Location: winlock, wa Status: Offline Points: 14723 |
Quote Reply
Posted: 16-November-2019 at 10:56AM |
yeah i don't get that??? spend twice the effort to do sh*t halfass
than to just do it right! and be done with it ![]() ![]() ![]() i mean geez, if it's mangled that bad straighten what you can then cut a good section from another car and graft it in !!! |
Quote Reply
Posted: 17-November-2019 at 4:30AM |
frame pulls are pretty cheap, considering those guys work miracles in short time
schufitz
Quote Reply
Posted: 11-December-2019 at 7:26PM |
Any updates Josh? Just curious to see what was found
Post Reply
| Tweet |
