1971 Torino GT - Need Kickdown Linkage for a 429 |
Post Reply
| Author | |
croakernorge
Joined: 26-July-2013 Location: Easton, Pennsyl Status: Offline Points: 11 |
Quote Reply
Topic: 1971 Torino GT - Need Kickdown Linkage for a 429Posted: 07-October-2013 at 6:13AM |
My Marti report indicated I originally had a C4 cruise o matic but I need to verify if I still have the C4 or a C6. At the Carlisle show this weekend a Ford vendor said that the C4 would not have mated up to the 429 that it should be a C6. The car originally had a 351-C in it but was swapped at some point.
I want to put my original column shifter to use and get rid of the B&M that someone installed. The shop I work with said I'm missing my kickdown linkage and brackets to swap over the original shifter. Anyone have any available or know what I should be looking for? Would comparable year Thunderbirds or Galaxies fit this? Not having an easy time. Thanks. |
croakernorge
Quote Reply
Posted: 10-October-2013 at 3:22PM |
Just an update I confirmed tonight my Torino does have the C6 transmission. The prior owner disconnected the stock linkage to use a B&M shifter. My local classic shop told me my original linkage was missing. I did look around online and see Lokar makes a kit but the original specs looked like it was a rod. Anyone ever used a Lokar or similar cable system to restore the original column shifter? Thanks.
GranTorinoSport
Admin of "The Org" Joined: 20-May-2003 Location: Seattle Status: Offline Points: 2290 |
Quote Reply
Posted: 10-October-2013 at 6:08PM |
Have the Lokar kit but have not installed it yet. I do think it is the ticket for a kick down lever and they are easy to fit because you just cut them.
A little on the speedy side but you do get what you pay for. |
Webmaster |
Post Reply
| Tweet |
