  New Posts New Posts RSS Feed - 1971 torino gt
1971 torino gt
chingo813 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chingo813 Quote  Post ReplyReply Direct Link To This Post Topic: 1971 torino gt
    Posted: 11-October-2011 at 2:28PM
I have a 1971 torino gt that wen i turn on will stay runnin but wen i turn the headlights on will shut off even wen i step on the brakes to put it in gear or if i put it in reverse but if i put it in drive itll stay runnin i had the alternator check and it was good n bought a new voltage regulator......anyone have an idea
73 GT Sport 429 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73 GT Sport 429 Quote  Post ReplyReply Direct Link To This Post Posted: 13-October-2011 at 5:09PM
What is the voltage at the battery at idle? It should at least 13.5 in neutral. If you don't have a voltmeter, Advance Auto will check it for free.
By the way, we go to the Fl Strabery Festival Festival every March. You live about 40 miles from me.
Mark
original owner-93 Lightning
73 Gran Torino Sport 429 (prodigal son)
Post Options Post Options   Thanks (0) Thanks(0)   Quote chingo813 Quote  Post ReplyReply Direct Link To This Post Posted: 13-October-2011 at 11:19PM
Thanks ill check it out this sat some people at work told me it might be the vacuum lines or canaster n yes the strawberry festival is like 5 mins from my house
VorbottenO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VorbottenO Quote  Post ReplyReply Direct Link To This Post Posted: 14-October-2011 at 3:00AM
It could be vaccuum especially if you have hideaway lights that require vaccuum to operate.
Again though, could be electrical and the additional draw of the brake lights, headlights, etc... robbing the ignition system.
Electrical is an easy no cost check.
Eric
72GTS-Ncode (429-477ci)
