  New Posts New Posts RSS Feed - 1972 429 motor , DOVE-C heads ? and #s
1beautifuldaughter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1beautifuldaughter Quote  Post ReplyReply Direct Link To This Post Topic: 1972 429 motor , DOVE-C heads ? and #s
    Posted: 08-September-2021 at 3:53PM
I hope my question makes sense, I am looking at a 72 ranchero N code car 429. The motor obviously has had things done as far as aluminum intake, holley carb, new style distributor, etc. I was thinking it might be a value issue down the road if the motor is not original. I have been sent photos of the casting behind the starter, ( maybe partial ) D1VE , and the heads say DOVE-C , so I started trying to research whats going on and it seems the block casting is just a overall 429-460 ID covering many years unless it has other marks after that I can't see.? So short of seeing the vin someplace on the block I am thinking that does not prove or disprove much of anything regarding the year. The heads say DOVE-C and according what I read the 72 would have had D2 something but where not good so maybe they where changed to improve things during a rebuild? Basically I am wondering if anyone could just set me strait on whats good or bad. Is a 429 better than a 351 ? is a 429 thats been altered for improvement better than one with original heads that would be correct? I think its a good car I am looking at, and has really nice options, gage cluster, performance suspension, A/C power everything. I just wish I knew more about the 429 motors. The seller has been very helpful,Not sure if he really knows much about it. He thought maybe the D1 on the block made it a 71 date motor. it's too far away for me to look at in person.I like buying things that are factory generally, but in this case I just need someone in the know to school me on what the DOVE-C heads would be and if they are a good or bad thing?? supposedly the motor runs very well.   I hope My rambling question is understood.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 08-September-2021 at 4:22PM
Could also be a 460, since they are MUCH more plentiful than a 429 and having 31 extra cubes isn't a bad thing in my mind. The DOVE-C heads are closed chamber castings with around 75cc's, they are WAY better than D2VE heads which are very prone to detonation. If the '72 was an early model, say mid to late '71 it could have possibly came stock with the DOVE-C heads. A big block is usually more desirable than a small block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1beautifuldaughter Quote  Post ReplyReply Direct Link To This Post Posted: 08-September-2021 at 4:25PM
Thanks, The car was built June 72
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 09-September-2021 at 2:16PM
The parts catalog shows that the 72 Torino should have had a part number of D1VZ 6010-A or D2SZ 6009-A.  it shows the Cylinder Heads as D2VZ 6049-B.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 09-September-2021 at 4:24PM
you can easily find out the displacement by sticking a long wooden dowel in a spark plug hole, and rotate the crank tilbthe stick is as far down as it goes. Mark the edge of the hole.  Now rotate so the stick come up as high as it will go. Mark it again.  Now measure the distance between the marks.
A 429 will have be slightly over 3.5”
A 460 will be slightly over 3.75”
I bet you probably have a 429...  but a 460 would be a nice surprise
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 10-September-2021 at 10:27AM
FYI, all 429 and 460 blocks can be bored .080 over the stock 4.36" bore. With sonic checking, some can go .160" over. Every .030" over bore adds about 5CI.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1beautifuldaughter Quote  Post ReplyReply Direct Link To This Post Posted: 11-September-2021 at 11:58PM
Thanks all, Good stuff to know, I went ahead bought the car. Whatever it is under the hood ,seems whoever worked on the car may have known what they where doing if its got better heads than born with. Wish me luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 12-September-2021 at 5:21AM
   Buy it. N code cars were not produced in great numbers. D1 block was definitely cast in 71. The heads were nost likely swapped out after finding a set and replacing the multi groove factory valves for the proper single grooves.
351CJ was a performance built engine whereas the 429 was not. Either one still can put power to the wheels when done right.
ETA: I am only sharing my opinion. I haven't had a 351CJ or 460 since the early 80s.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1beautifuldaughter Quote  Post ReplyReply Direct Link To This Post Posted: 12-September-2021 at 8:52AM
Yah , I went ahead and bought it, Its 429 N code, C-6, 3:35 traction lock, Performance Suspension package, Rally gage dash, Rally wheels, PDB, PS, Power windows, A/C. Thinking of doing it in Gold Glow to match my GTS, and have a truck when I need it.   Thanks Again
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 12-September-2021 at 9:36AM
Well done, I'm sure you will like that, especially with having the cousin Gran Torino for common parts and service work for them both.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1beautifuldaughter Quote  Post ReplyReply Direct Link To This Post Posted: 13-September-2021 at 11:27AM
Thanks, Should be here in about a month.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 13-September-2021 at 12:09PM
Wow, that looks awesome!  Should be really nice with a built 429.  If you get the Marti, I'd love to see it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1beautifuldaughter Quote  Post ReplyReply Direct Link To This Post Posted: 13-September-2021 at 12:17PM
Compton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 13-September-2021 at 1:26PM
I reckon it looks pretty good in the brown…very period…sweet ride mate
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1beautifuldaughter Quote  Post ReplyReply Direct Link To This Post Posted: 13-September-2021 at 1:34PM
It's no question an interesting assortment of colors, : )
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1beautifuldaughter Quote  Post ReplyReply Direct Link To This Post Posted: 13-September-2021 at 1:36PM
Maybe hence the reason only 34 made with color and trim options ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 13-September-2021 at 2:16PM
   Very nice. Looking forward to more pics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 13-September-2021 at 3:56PM
All the more reason to keep it brown if there’s only 34….
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 13-September-2021 at 5:30PM
very nice! 429 C6 and a 3.25 locker... very cool Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 13-September-2021 at 5:39PM
that sure looks familiar... did you buy it from a guy in oregon by chance?
AUS GTS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AUS GTS Quote  Post ReplyReply Direct Link To This Post Posted: 13-September-2021 at 8:25PM
Nice buy! enjoy!
Al
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1beautifuldaughter Quote  Post ReplyReply Direct Link To This Post Posted: 13-September-2021 at 11:24PM
I think its born and raised in Arkansa
This page was generated in 0.133 seconds.
