  New Posts New Posts RSS Feed - 1972 429
1972 429
68dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 68dave Quote  Post ReplyReply Direct Link To This Post Topic: 1972 429
    Posted: 24-September-2008 at 7:31AM
Found a rough  '72 Torino with a  429.  How can I confirm the engine is a 429?Clap
73GTS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Posted: 24-September-2008 at 3:08PM
Part numbers!
Block
Heads
Intake
Big%20smile
PatsPOS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PatsPOS Quote  Post ReplyReply Direct Link To This Post Posted: 24-September-2008 at 3:14PM
The easiest way to tell engine families apart is by counting the valve cover bolts.  The Windsor family (289, 302, 351W, to name a few) has six bolts, the 335-series (351C, 351M, 400) has eight, and the 385-series (370, 429, 460) has seven.
Now, if you're asking how to tell a 429 from a 460, the easiest way I know of is to check the crankshaft...externally, there are no differences.
HTH,
Pat
'75 460 Gran Torino Sport (14.04 @ 97 MPH)
'91 Crown Vic (18.09 @ 75 MPH)
'89 300 F-150 (18.37 @ 73 MPH)
bay0726 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bay0726 Quote  Post ReplyReply Direct Link To This Post Posted: 13-July-2010 at 12:44AM
The Vin number should be stamped in the rear of the drivers side of the block clost to the firewall. It might not be possible to see it with the engine in the car.
VorbottenO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VorbottenO Quote  Post ReplyReply Direct Link To This Post Posted: 16-July-2010 at 6:42AM
Does it look like any of these?
Eric
72GTS-Ncode (429-477ci)
fisheadlee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fisheadlee Quote  Post ReplyReply Direct Link To This Post Posted: 02-February-2011 at 1:21AM
The valve covers are different, I believe the 429 has 7 mounting holes  460 has 6.
When in doubt, whip it out
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Posted: 02-February-2011 at 9:01AM
Originally posted by fisheadlee fisheadlee wrote:
The valve covers are different, I believe the 429 has 7 mounting holesĀ  460 has 6.
No difference between the 2.
Jim
This page was generated in 0.101 seconds.
