  New Posts New Posts RSS Feed - 1972 Ford Torino Steering Box - Quicker?
Ron Earp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron Earp Quote  Post ReplyReply Direct Link To This Post Topic: 1972 Ford Torino Steering Box - Quicker?
    Posted: 27-November-2010 at 4:19AM
Check this out:
http://www.hemmings.com/mus/stories/2007/09/01/hmn_feature21.html
Great article covering various ways to get a quick ratio box using factory parts. Alas, according to the article it appears the 72 Torino has the less popular 605 box instead of the 800 box.  This is denoted by the snap ring holding the pitman shaft cover on instead of a cover with bolts.
The steering ratio on this car is abysmal and I need to correct it. Something along the lines of 12.7:1 ratio and around 2.25:1 turns lock to lock or quicker is what I'm after.
Does anyone know of a source for steering box rebuilds that can do this job?
04 Ford Lightning
72 GTS BB Stroker & Toploader
98 Mustang ITS SCCA #38
08 Buell Ulysses
GT40s.com
Torinogts73c View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Torinogts73c Quote  Post ReplyReply Direct Link To This Post Posted: 27-November-2010 at 6:46AM
Try a Saginaw steering box out of 71-73 Mach 1 They are variable ratio boxes will work in Torinos with a few minor mods. I have had one in my car for 20yrs! Much quicker than the Ford box. I think the tag code is SPA-R . Also you will need hoses for a Torino with a Saginaw gear. There is a bow tie looking adapter to connect with your coupler that you will need as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 27-November-2010 at 6:52AM
I really wish I could find a quicker ratio manual steering box for my 72.
13 Taurus SHO "Mr Pig"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron Earp Quote  Post ReplyReply Direct Link To This Post Posted: 27-November-2010 at 1:23PM
I'm going to try these folks first:
http://www.powersteering.com/
Looks like if any company could help they could.
04 Ford Lightning
08 Buell Ulysses
GT40s.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Torinogts73c Quote  Post ReplyReply Direct Link To This Post Posted: 28-November-2010 at 4:45AM
Let me know how that works for you! I wouldn't mind upgrading my steering gear!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron Earp Quote  Post ReplyReply Direct Link To This Post Posted: 28-November-2010 at 7:19AM
Well, as someone else wrote, no dice. They got back to me and said they can't rebuild that box for a quicker ratio. I'm sure someone could do it, but since the popularity is low nobody does it commercially.
They suggested I move to a Saignaw box in the Mustang as mentioned above. So I'm checking with them on the parts cost and might send them my box so they can have a look at the stock Torino arm and so on. I'll keep you posted.
R
04 Ford Lightning
08 Buell Ulysses
GT40s.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Torinogts73c Quote  Post ReplyReply Direct Link To This Post Posted: 28-November-2010 at 9:13AM
The Saginaw is really the better box!! I had control valve problems with my Ford box and that was why I made the change.
TopGear (TG) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TopGear (TG) Quote  Post ReplyReply Direct Link To This Post Posted: 29-November-2010 at 11:48AM
I have a manual steering setup in my Nissan and wish sometimes I could convert my 76 to manual. If it's possible, how?
Yes, I know I will regret going to manual at times, but I mainly only drive this car on the highway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 29-November-2010 at 2:31PM
I am going with a RACK AND PINION SET UP!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron Earp Quote  Post ReplyReply Direct Link To This Post Posted: 06-December-2010 at 9:29AM
Torinogts73 (would be easier if you guys used names Smile), what did you have to do to convert to the Saginaw box?  I'm still hitting dead ends for anyone who will touch a Ford box.
I also looked at the Flaming River rear steer rack and might just go that route. I need to get the suspension on the car and at an approximate ride height to see if that will work or not.
04 Ford Lightning
08 Buell Ulysses
GT40s.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 06-December-2010 at 9:33AM
#1.
SPA-T is a variable ratio 3 turn box from a 7-73 Mustang that will bolt into our cars. I have one in my car now.
#2.
Larescorp will rebuild your box with quicker internals.
#3.
A Jeep Grand Cherokee box will bolt in. Unsure of hose connections (minor detail) or stops (major detail). Chevelle guys have been using these for years.
Junk the Ford box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron Earp Quote  Post ReplyReply Direct Link To This Post Posted: 06-December-2010 at 9:43AM
Thanks for the information, great leads there. Any particular years I need to look for one the JGC?  Lines and hoses are no big deal, like you say, but the stops could be.
I wouldn't mind using a Ford box rebuilt as it doesn't much matter what sort of box it is except that the ratio be quick.
That SPA-T varies from like 18:1 to 14:1 doesn't it?
04 Ford Lightning
08 Buell Ulysses
GT40s.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 06-December-2010 at 9:49AM
SPA-T, Something like that. It was a night and day difference in my Cougar. Love it. It uses Saginaw SAE lines, but so did some 72 Torinos.. I just bought new hoses.
I posted on the JGC box before.
Edited by Psquare75 - 06-December-2010 at 9:50AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron Earp Quote  Post ReplyReply Direct Link To This Post Posted: 06-December-2010 at 10:16AM
I'll check that out.
Will a damn Saginaw box bolt on to the frame?  Dime a dozen in quick ratios for like $350.
04 Ford Lightning
08 Buell Ulysses
GT40s.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Torinogts73c Quote  Post ReplyReply Direct Link To This Post Posted: 06-December-2010 at 10:27AM
I had to change the hoses (Ford used Saginaw boxes on Torinos) 73-76 Torino Montego Etc, There is an adapter from the box to the coupler to complete the install.  BTW my name is Gary!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron Earp Quote  Post ReplyReply Direct Link To This Post Posted: 06-December-2010 at 12:02PM
So you just used a Saginaw box?
Did it bolt in the same position with the addition of holes in the frame?  If that is all it takes I'm sold. Lines are no problem - I'm not using a Ford pump anyhow and have no lines, so I'll have to have some made no matter what steering box I use.
Any problems with the pitman arm and linkage?
R
04 Ford Lightning
08 Buell Ulysses
GT40s.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 06-December-2010 at 2:13PM
Same holes in the frame. I used the pitman arm from my car on it. (Regarding the Mustang Saginaw box). I got my SPA-T box on ebay for $50 a few years ago. Larescorp has em for $275 I think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Torinogts73c Quote  Post ReplyReply Direct Link To This Post Posted: 07-December-2010 at 12:15AM
Ditto, I bolted mine right on used the same pitman arm as well. My box came off of a 71 Boss 351 Mustang. SPA T   Eliminated all the grief from my Ford box!
iangj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iangj Quote  Post ReplyReply Direct Link To This Post Posted: 07-December-2010 at 1:19AM
There are a couple of them on eBay right now.
Ian Glyn-Jones
Fonthill, Ontario, Canada
Wish I had My Baby Back
Montego GT Registry
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron Earp Quote  Post ReplyReply Direct Link To This Post Posted: 08-December-2010 at 7:26AM
UPDATE:
Larescorp was the ticket.
Called those guys and they crossed referenced to a 800 series Saginaw box that they can rebuild with three turns lock to lock and around a 12.5 ratio, as well as firm it up.  $275 for a newly rebuilt box that they can ship by the end of the week. Uses the stock Ford Pitman arm, needs a $35 coupler that they offer, and uses the same three bolt mounting holes.
Thanks for the help, I'll report back how it works out!
R
04 Ford Lightning
08 Buell Ulysses
GT40s.com
stuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stuck Quote  Post ReplyReply Direct Link To This Post Posted: 08-December-2010 at 6:07PM
 this company may have info and should be good to deal with http://www.borgeson.com/
michigan
Post Options Post Options   Thanks (0) Thanks(0)   Quote stuck Quote  Post ReplyReply Direct Link To This Post Posted: 08-December-2010 at 6:14PM
i missed page 2 never mind what i said ,thanks for the update
michigan
bigblocktisdale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigblocktisdale Quote  Post ReplyReply Direct Link To This Post Posted: 09-December-2010 at 10:08AM
are you going with a rear steer rack or going to convert everything to front steer?
1972 Gran Torino Sport : 10.30 @ 131 mph NA
1991 mustang : 11.38 @ 123 mph sold 91 and bought a 67 mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 09-December-2010 at 10:36AM
I had a link here that detail a R*P install in a 64 Galaxie, which is close, frame-wise, to a Torino.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 09-December-2010 at 3:34PM
putting an Explorer rack in the rear steer set up.
Looks like it will fit.
I am using the whole Accessory brackets, alt, A/C compressor, PS Pump, and water pump so stock lines for the Explorer will work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 09-December-2010 at 3:36PM
Anyone have the SPECS for the tie rod end?
I am looking for the taper degree and length on the 72 and then compare it to the 96 Explorer.
IF that is not the same then I might may need to look into a different tie rod end OR cut the spindle to match the taper of the Explorer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 09-December-2010 at 4:46PM
Well, my thoughts if you are converting to the rack system, something I have seen on a couple conversions for the mopar crowd, is doing a bump steer elimination kit, reaming out the tie rods for hem joints with new hardware, and done. Only issue is no returning the spindles back one you ream them out to fit a straight shaft bolt setup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 09-December-2010 at 4:56PM
That was/is my other option.
Still looking to see about that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 09-December-2010 at 5:37PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 10-December-2010 at 1:35AM
Originally posted by Psquare75 Psquare75 wrote:
http://web.archive.org/web/20040104071115/http://home.pacbell.net/ssixto/automotive/R&P/HowTo.html
Not sure what that link is for but it doesn't work
This page was generated in 0.160 seconds.
