  New Posts New Posts RSS Feed - 1972 Gran Torino blower motor
Jayme1972 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jayme1972 Quote  Post ReplyReply Direct Link To This Post Topic: 1972 Gran Torino blower motor
    Posted: 02-March-2025 at 10:22AM
I am trying to replace the blower motor in a 72 Grand Torino ac car. I have removed all the screws but it still don’t want to break loose. I don’t want to damage the housing. Is there something I am missing? Would appreciate any help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2025 at 11:17AM
Not sure but I beleive there are bolts/nuts on both sided of the firewall to remove.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 05-March-2025 at 4:55PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 05-March-2025 at 5:05PM
as far as the blower fan housing, it can be sort of a pain.
There are six hex head screws holding the lower housing to the upper housing. Usually find it easier to pull the whole housing out of the dash to service.
On the far right, there is one screw that is a real pain to get to. Need to use a 12" extension on a ratchet or small low RPM cordless drill/ratchet.
I would disconnect the vacuum motor from the damper door.
6 hex head screws, and ground wire for the fan.
disconnect hot power lead to fan.
I leave the upper blower housing bolted to the firewall and drop the lower housing with the fan motor.
Pvt.Joker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pvt.Joker Quote  Post ReplyReply Direct Link To This Post Posted: 08-March-2025 at 9:32AM
Andrew, if it isn't too much trouble, would you mind posting the manual pages that have the diagrams for the heater-only set-up that shows the blower and the ductwork layout like in the A/C version photos above? I'm trying to figure mine out so I can install the new heater core in the box and attach it to the ductwork on the dash, and also to swap the blower motor (if it needs it) before I try to hang the dash on my non-A/C 1972 Gran Torino and diagrams are really useful in figuring out what parts go where, since I wasn't the one who disassembled it originally. Thanks!
This page was generated in 0.127 seconds.
