1972 Gran Torino Sport Fastback |
JFN
New Member Joined: 23-January-2022 Location: Du, Status: Offline Points: 3 |
Posted: 23-January-2022 at 12:45PM |
Would anyone know where I can get a full floor pan for my 72 Gran Torino Sport Fastback
Compton
Senior Member Joined: 22-April-2017 Location: Auckland Status: Offline Points: 627 |
nowhere if you want new ones...the "stamped" repros are average at best and aren't very similar....i (meaning my fabricator) will be fitting 71-73 Mustang full length pans in mine in the near future and will post how it goes...i do foresee some modifications..
good second hand ones or fabricating pieces to fix yours are your only options if you want to keep the stamping as per factory... |
JFN
This really sucks as all second hand floor pans are trashed. I will keep looking thank you for this information.
picon3
Senior Member Joined: 20-February-2007 Location: North Carolina Status: Offline Points: 2096 |
Back when I was working on my car's restoration, I ran into the same problem; then one day I stumbled onto a 1976 wagon with immaculate floors. The shop cut out the whole floor from the firewall back and with a little fabrication... Perfecto. Paul
1972 GTS 351CJ-4V black/black
Greg73Oregon
Senior Member Joined: 23-February-2021 Location: Roseville, CA Status: Offline Points: 232 |
Look in the "Project Forums". A member is in the process of replacing his floor pan issues.
The title of the post is:
GKF
Eliteman76
My mentality is: it's metal: Chop cut weld.
Like it or not, you have to be open to alternative metal. Floor pans, look to a late model crown vic or Lincoln Continental. For replacement metal, some folks have used Mustang floor pans. Flipped them left to right but you have to search. Trunk floor pans, Chevelle 70-72 would work. Same for Oldsmobile Cutlass/442 of the 70-72 era. It's not exactly the same but it's metal. #chopcutweld
Pondering: #99Problems |
