  New Posts New Posts RSS Feed - 1972 GTS clutch rod boot.
Anderslober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Topic: 1972 GTS clutch rod boot.
    Posted: 16-September-2022 at 1:38AM
Wow…parts are hard to find for this year!😲
I need a clutch rod boot. The part I bought is to small in diameter.
The hole  is 2 1/2 inches. We need someone to make boots for our cars! Any ideas welcome. Thanks.
Edited by Anderslober - 17-September-2022 at 9:03PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2022 at 5:22AM
can you post a link to what you got?
some info in my project thread
https://forum.grantorinosport.org/rockatanskys-72-ranchero_topic5563_page2.html
Yellosn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Yellosn Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2022 at 7:30AM
I’ve been looking for a replacement boot too. I’ve never come across a NOS unit. Mine came with a 4 speed so I need to find something that will fit in that 2 1/2” factory hole. I’m sure I could figure out something that would “work”, I just wish I could find something that is, or looks, OEM.
Troy Emerson
Eugene, Oregon
1972 GTS 4speed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 17-September-2022 at 9:00PM
Here is the part I bought. It does NOT fit. It is to small in diameter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 18-September-2022 at 4:46AM
yes the C60Z-7533 part has been confirmed not correct (too small) to fit the existing hole in the firewall but can be used for auto - manual conversions as you'd be making your own hole
do you have anything left of your original boot, what does it look like, anything like this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 18-September-2022 at 9:28PM
The old boot looks exactly like the boot I bought. It is just bigger.
Was the 72 GTS/4spd the ONLY car that used the bigger boot??.
That cant be true………………..hopefully.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 21-September-2022 at 2:10AM
Here is a picture of what is left of the original boot…👇 Big metal ring holding it in place on car….
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 21-September-2022 at 8:45PM
Part number of original boot is :D20A-7A533-AA.
Is that available anywhere?👍🤠
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 23-September-2022 at 10:44AM
do you think you could trim the old boot down and RTV the new boot into the section that fits the hole in the firewall?
clean it real good with carb cleaner or brakleen and the 2 should become 1
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 25-September-2022 at 3:30AM
Unfortunately this seal was only used on 1972-74 Torinos with manual transmissions.  It is not reproduced and super rare.  I'd do google searches for the part number to see if any show up. Otherwise, check place that specialize in NOS parts like Green Sales.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 25-September-2022 at 4:41PM
It doesn't help any but someone around here was working on those. I bought one of the trials. Can't remember off hand who it was.
08 Taurus (Maytag)
03 Dakota (Rusty)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 28-September-2022 at 9:49PM
I put the new boot into the old boot…..perfect fit! Looks good.🤠👍
Post Options Post Options   Thanks (0) Thanks(0)   Quote Yellosn Quote  Post ReplyReply Direct Link To This Post Posted: 29-September-2022 at 3:29PM
By new boot do you mean the C60Z-7533 you bought? What exactly did you use to bond it to the old base? Got a pic to share?
Thanks, Troy
Troy Emerson
Eugene, Oregon
1972 GTS 4speed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 30-September-2022 at 3:04AM
I just stuffed the new boot in the old boot……no glue or anything.
Will take piicture……
This page was generated in 0.105 seconds.
