  New Posts New Posts RSS Feed - 1972 RADIATOR SUPPORT
SEKCOBRA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Topic: 1972 RADIATOR SUPPORT
    Posted: 23-March-2022 at 8:18AM
Im looking for a 1972 radiator support. If anyone is parting a car or knows where one might be please contact me at 516-713-3280
Thanks Steve
69 MACH R CODE
70 TORINO COBRA J CODE
71 TORINO COBRA J CODE
72 Z28 CAMARO
94 MUSTANG 5.0 LX NOTCH
72 GTS Q CODE
61 Galaxie 427
62 Galaxie 406 tri power
64 Galaxie country sedan 390
1972 GTS Q CODE
Gold73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gold73 Quote  Post ReplyReply Direct Link To This Post Posted: 24-March-2022 at 12:40PM
You might check with Sean Steen. He from New York.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 26-March-2022 at 11:05AM
Bring lube.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 26-March-2022 at 11:19AM
69 MACH R CODE
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
1972 GTS Q CODE
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 26-March-2022 at 11:23AM
Hi Steve, do you have to use the 72 part with the correct holes/threads for the 72 hood latch etc? The other models and years will work, you'd have to rework the mounting of the latch though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 26-March-2022 at 11:31AM
I would prefer to find a 72 support. If I can't then all options on the table.
69 MACH R CODE
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
1972 GTS Q CODE
67gt5003119 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67gt5003119 Quote  Post ReplyReply Direct Link To This Post Posted: 26-March-2022 at 5:40PM
I have one. PM me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 27-March-2022 at 12:25AM
PM sent
69 MACH R CODE
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
1972 GTS Q CODE
pete rad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pete rad Quote  Post ReplyReply Direct Link To This Post Posted: 27-March-2022 at 2:15AM
There are three radiator supports for sale, but I do not know if they will ship the part to you. If you are interested, you will have to call them.
1972 Radiator/Core Support Ford Torino Ranchero, very good condition, stock number: N-59, Big Junkyard & Auto Gallery of Spotswood new jersey, 732-416-0441 / 732-416-0207
1972 Radiator/Core Support Ford Torino, very good condition, stock number: 15A036, B & S Auto Salvage of Wildwood florida, 352-748-1150
1972 Radiator/Core Support Ford Torino, very good condition, stock number: B2395, Barger-Mattson of Twin Falls idaho, 1-800-632-0836
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 27-March-2022 at 6:45AM
Thanks, Call tomorrow
69 MACH R CODE
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
1972 GTS Q CODE
Post Options Post Options   Thanks (0) Thanks(0)   Quote pete rad Quote  Post ReplyReply Direct Link To This Post Posted: 28-March-2022 at 4:08AM
Your welcome
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67gt5003119 Quote  Post ReplyReply Direct Link To This Post Posted: 29-March-2022 at 5:18PM
Steve, I sent you some pics,  did they come through?
Cheers
Rob
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 01-April-2022 at 11:57PM
PM sent
69 MACH R CODE
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
1972 GTS Q CODE
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 18-April-2022 at 8:55AM
Called all of these guys. So frustrating dealing wih morons everyday. The guy in NJ told me he had it and would call me back the next day everyday for two weeks. Then after two weeks says he doesn't have it. Bunch of young kids who could care less about customers. Anyway thanks for the leads. Bak to the hunt.
69 MACH R CODE
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
1972 GTS Q CODE
Post Options Post Options   Thanks (0) Thanks(0)   Quote pete rad Quote  Post ReplyReply Direct Link To This Post Posted: 01-May-2022 at 4:39AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote pete rad Quote  Post ReplyReply Direct Link To This Post Posted: 01-May-2022 at 5:27AM
There is a radiator support for sale from a '73 to '76 torino ranchero. But i do not know what is different about it when compared to a '72 gran torino radiator support. Maybe one of the other members might know.
Edited by pete rad - 01-May-2022 at 6:19AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote pete rad Quote  Post ReplyReply Direct Link To This Post Posted: 01-May-2022 at 5:52AM
The two pictures below compare the '72 support to the '73 support. The '72 support is the one on top and the '73 support is below the '72 support.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pete rad Quote  Post ReplyReply Direct Link To This Post Posted: 01-May-2022 at 6:26AM
In the pictures below it might appear that the '72 support is slightly taller in the area of the hood latch area than the '73 support. But maybe it is because of the different angles that the pictures were taken on. The '72 support is on top and the '73 support is below.
According to the members below the two supports are very similar or almost the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 01-May-2022 at 7:46AM
I swapped a 72 front end onto my 73 in 1989, the radiator supports are functionally the same. I had two spare 72 Sport front ends, one the radiator support was rusted badly and I scrapped it. I think I used my 73 support for the swap, coating it before the swap. I lost track of the other support, I don't have that spare anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 01-May-2022 at 8:07AM
Thanks for the lead
69 MACH R CODE
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
1972 GTS Q CODE
Post Options Post Options   Thanks (0) Thanks(0)   Quote pete rad Quote  Post ReplyReply Direct Link To This Post Posted: 02-May-2022 at 1:33AM
Your welcome
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 02-May-2022 at 3:30PM
I thought they were all interchangeable.  I guess californiaJohnny would be the guy to ask—-
Post Options Post Options   Thanks (0) Thanks(0)   Quote pete rad Quote  Post ReplyReply Direct Link To This Post Posted: 02-May-2022 at 6:04PM
There is a member that used a radiator support from a '74 gran torino on his 1977 thunderbird, and he said that it fit with no issues. I might be able to find the thread if you want me to.
The pictures below compare a '72 gran torino support to a 1979 ranchero support. The '72 support is on top and the '79 support is below the '72 support. They appear to be almost identical.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pete rad Quote  Post ReplyReply Direct Link To This Post Posted: 02-May-2022 at 6:06PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 03-May-2022 at 9:38AM
Thanks again Pete. I would buy his if I knew for a fact that it will work for what I need. Mine is like a lot of these, its rusted in the left lower section where the body mount is. I just need that section. I plan to cut out the bad part and weld in a new piece. Does anyone know if this support for a 79 Ranchero is the same as a 72 in that area??
Thanks
69 MACH R CODE
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
1972 GTS Q CODE
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 03-May-2022 at 9:48AM
I'm sure you can use another support from the many mid sized 70's Fords to repair your 1972 part. I thought they were all the same until someone in another thread posted that the top center area might have different bolt holes due to the differing hood latch brackets. I didn't notice any real difference in my 72 versus 73 supports, but that was in 1988 when I did that swap. I'd bet the rest is all the same, maybe some odd unseen bolt holes for the inner fenders could have changed a hair over the years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pete rad Quote  Post ReplyReply Direct Link To This Post Posted: 03-May-2022 at 9:50AM
Your welcome. There is a picture below of the lower section where the body mount is, the radiator support below is original from a 1979 ranchero.
Edited by pete rad - 04-May-2022 at 8:38PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 03-May-2022 at 2:47PM
Sekcobra,
Is the rust in the “lower left” as you look at it in a pic, or do you mean lower left as in “driver side”?
Can you show me a definitive pic of what is bad on yours, and I can compare to my partial core support to see if it’s the corner I have it not?
Dave Fox
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 03-May-2022 at 3:33PM
Passenger side
69 MACH R CODE
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
1972 GTS Q CODE
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 03-May-2022 at 4:13PM
Well, unless I’m looking at things wrong, it sure looks like mine has the section you need.  Take another look at the pic I sent you... it was sent to your inbox back on March 26.
Dfox
