  New Posts New Posts RSS Feed - 1972 RADIATOR SUPPORT
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 03-May-2022 at 5:21PM
Mine had the rotted section replaced. The section is missing at least one small hole where the plastic fastener holds on the strip of rubber(?) along the top edge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 03-May-2022 at 5:23PM
The piece that was grafted on is from a support that hogfiddles has the  rest of.
pete rad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pete rad Quote  Post ReplyReply Direct Link To This Post Posted: 04-May-2022 at 8:51PM
There are two pictures below of the passenger side of a '79 Ranchero original radiator support, where it mounts to the body.
SEKCOBRA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 07-May-2022 at 1:04AM
Hi Dave
Sorry for late response. My computer is in the shop. Using my phone. If that is solid in the passenger side lower corner that is what I need. Let me know what you want for it shipped to Farmingdale NY 11735
Easier to call me at 5167133280
Thanks
69 MACH R CODE
70 TORINO COBRA J CODE
71 TORINO COBRA J CODE
72 Z28 CAMARO
94 MUSTANG 5.0 LX NOTCH
72 GTS Q CODE
61 Galaxie 427
62 Galaxie 406 tri power
64 Galaxie country sedan 390
1972 GTS Q CODE
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 07-May-2022 at 1:22AM
I’ll look at mine again in the daylight, but looking at it the other night, I believe it’s the driver half that I have :(
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 11-May-2022 at 2:16PM
Yep, it’s the driver’s side that I have……:( sorry
Dfox
