  New Posts New Posts RSS Feed - 1972 Trunk ornament
1972 Trunk ornament
wideone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wideone Quote  Post ReplyReply Direct Link To This Post Topic: 1972 Trunk ornament
    Posted: 26-May-2012 at 4:24PM
I have never had one of these off.  Do you just drill out the rivet?  Once it is off, can it just be left off?  Is there an extra hole that needs to be filled?
Thanks
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 26-May-2012 at 6:25PM
should have barrel clips holding it on like the Gran Torino emblems
got a photo ? if it has a rivet somebody might have pop riveted them on at one point but the should be small holes for the studs of the emblem behind it that would need to be welded up if you intend to leave them off
Post Options Post Options   Thanks (0) Thanks(0)   Quote wideone Quote  Post ReplyReply Direct Link To This Post Posted: 03-June-2012 at 2:14PM
Thanks, got it out without breaking it.  One side had the barrel nut, the other had a rivet.
I' figure out which barrel nut to use when I put it back.
