1973 Torino clutch linkage rebuild |
anchovieMAN
Member Joined: 19-January-2021 Location: Wisconsin Status: Offline Points: 70 |
Posted: 01-May-2022 at 12:00PM |
Hello everyone. I’m currently working on getting the pieces restored for a 4 speed swap. I have the factory parts needed to do it and am running into one problem. The z bar for the clutch linkage is a bit worn out. The bushing for the arm that pushes the clutch in is shot, as well as the bushings that the bar pivots on could be replaced. Does anyone have any information on how to take apart the bar to rebuild it and where I could buy new bushings? Any help is appreciated.
Thanks, Jay
Jayden
Yellosn
Member Joined: 14-February-2020 Location: Eugene, OR Status: Offline Points: 134 |
Great article here I used when I did mine. I got the z bar rebuild kit from autokrafters.
Troy Emerson
Eugene, Oregon 1972 GTS 4speed |
Yellosn
Thanks(1)
Before and after. I had a buddy weld up the wobbled out part and then re-drilled the hole. I got the bushing at coastal farm and fleet.
Troy Emerson
handsofstone
I may have a decent Z-bar at the garage. I can look tomorrow.
Senior Member Joined: 30-July-2010 Location: On The Road Status: Offline Points: 6070 |
you're in for a fun time, some clutch linkage stuff in my project thread
https://forum.grantorinosport.org/rockatanskys-72-ranchero_topic5563_page2.html |
some pics that are missing from my project thread, the pivots were loose and wogged out so i welded them back to serviceable condition
anchovieMAN
The pivot ball is loose on mine but was also pretty rusted, so the new bushing kit wouldn’t be the best for it without replacing the ball. So I’m going to cut it out and go to a machine shop and have a new one made. Do you know what size hole you drilled and what size bushing you used?
Jayden
anchovieMAN
Do you know what size hole needed to be drilled and what sized bushings is needed?
Jayden
