1974 400/C6 - Junk it or keep it? |
Post Reply
| Author | |
unlovedford
Joined: 17-December-2010 Location: Tennessee Status: Offline Points: 10150 |
Quote Reply
Topic: 1974 400/C6 - Junk it or keep it?Posted: 15-August-2013 at 3:24PM |
I have a running 400 Modified and a C6 in a '74 Ranchero I just bought. Engine runs well, smells like OLD gas when I start it and puffs a small wisp of smoke (old gas?) when you first start it. Has been sitting 2 years. Truck shows 114K and verified by original owner. Is it worth going to the trouble of pulling it, or should I just leave it to add weight when I junk what is left?
legend onirot
METAL GOD Joined: 18-January-2009 Location: hattiesburg ms Status: Offline Points: 3038 |
Quote Reply
Posted: 15-August-2013 at 5:35PM |
put "new" gas in it?
Robbdtme
Joined: 06-June-2012 Location: Central WI Status: Offline Points: 765 |
Quote Reply
Posted: 15-August-2013 at 6:46PM |
Read up on 400's. Keep it. These are great motors that can easily and cheaply be built. 74 had larger chamber heads that later crappy 351m Heads can improve. The 400 always had low octane higher compression problems in the 70's. Again read up on 400's you will get excited and keep it.
Eliteman76
Joined: 20-March-2006 Location: Nebraska, USA Status: Offline Points: 5450 |
Quote Reply
Posted: 24-April-2014 at 7:01AM |
Joe, I am looking for a C6 for a 400. If you elect to part, let me know.
Andrew:GTS.ORG admin, '72 Q code 5 speed RestomodPondering: #99Problems |
unlovedford
Quote Reply
Posted: 24-April-2014 at 7:07AM |
Andy,
That all left here months ago. However, the '67 LTD has a non-original rebuilt 400/C6 in it that I am contemplating removing for an EFI drivetrain, since C wants to keep/drive this. Will let you know if I elect to remove it. |
Quote Reply
Posted: 24-April-2014 at 8:14AM |
OK I know it's an old dead thread but just to point out for anybody that finds it in a search for something else...
1974 400 heads are better than 1975 351M heads because of the exhaust port... chambers are basically the same. in 1975 with the D5 casting, Ford added a water jacket around the exhaust valve for added cooling due to higher running temps of the new unleaded fuel the exhaust port bowl is 'filled' & that's not a good thing bottom left pic here http://raceabilene.com/kelly/hotrod/newmotor2.html |
unlovedford
Quote Reply
Posted: 24-April-2014 at 9:19AM |
I have no idea what year the LTD's engine is. Just aware of it being rebuilt, pretty healthy, 4Bbl intake and Edelbrock carb and sounds like Christine. Moves the car pretty well and the transmission shifts well.
kychevyguy
Joined: 16-December-2013 Location: Lexington KY Status: Offline Points: 1996 |
Quote Reply
Posted: 10-August-2014 at 6:18AM |
What information does anyone have about the 1973 400 engine? The particular engine has had low oil pressure for the 15 years that the current owner has had it. Is this a notorious issue with the 400s? Is there something I should look for when purchasing??
JT, USAF Ret./Architect
Quote Reply
Posted: 10-August-2014 at 7:54AM |
yeah they're pretty famous for running almost forever with little or no oil pressure, as long as you don't kill them on purpose they keep chug'n. w/o going into the engine a HV oil pump can be a 'repair' method, or running slightly heavier oil or both
even after rebuild with new bearings & fresh reground crank they still have pathetic oil pressure. Tim Meyer did a thread showing how he custom ground the crank to outside service tolerance & came up with typical factory oil clearances, otherwise with quality replacement bearings & reground crank within service spec's you'll end up with 'performance' oil clearances & possibly crappy oil pressure kinda funny how the boat anchor of the late 70's turned out to be the choice of Engine Masters Competition builders in the 2000's
Edited by Rockatansky - 10-August-2014 at 7:56AM |
Post Reply
| Tweet |
