  New Posts New Posts RSS Feed - 1974 Elite Wheel Cylinders
Alice View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alice Quote  Post ReplyReply Direct Link To This Post Topic: 1974 Elite Wheel Cylinders
    Posted: 22-August-2023 at 10:30AM
Sorry new on here trying to help my sister she has a 74 grand Torino elite I’m having issues to find the rear left driver side drum brake wheel cylinder went to all auto stores just in diameter the new ones are bigger I really hope u can help me Don’t know if makes a difference it’s a hardtop supposed to be police package
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 22-August-2023 at 1:12PM
On the rear drum brakes, the wheel cylinder diameter can affect brake pressures.
Been a while but you need to make sure you stick to the same diameter because it can affect brake pedal pressure and brake pedal performance because the master cylinder bore size changes for the police spec cars.
You will best off to refer to Rayobestos and application guides.
RockAuto.com lists out the wheel cylinder size data.
Likely, you have a non-police package if it's a Gran Torino Elite.
I expect the diameter of the piston is 0.906"
7/8" is 0.875" diameter
15/16" police specs are 0.9375" diameter
Local parts stores can also cross these parts over.
RAYBESTOS WC37267  Info
Rear Left; Fastback; Hardtop; 2 door; without Police Package
RAYBESTOS WC37267 Specifications
Cylinder Bore Diameter (IN)0.906
RAYBESTOS WC37268  Info
Rear Right; Fastback; Hardtop; 2 door; without Police Package
RAYBESTOS WC37268 Specifications
Raybestos has a newer website that does list out part numbers. You need to search under 1974 Ford Gran Torino.
Hope this helps.
This page was generated in 0.147 seconds.
