  New Posts New Posts RSS Feed - 1975 Cougar / Montego front inner fenderwells
pyntre View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pyntre Quote  Post ReplyReply Direct Link To This Post Topic: 1975 Cougar / Montego front inner fenderwells
    Posted: 27-August-2023 at 3:39AM
What are the odds of finding rust free front inner fenderwells for these cars ? Or would there be a chance of getting patches cut out of a rust free part because of the labor involved in actually removing and shipping an entire inner fender ?!?!
The an arm dust flaps must hold moisture / snow/ salt  on these midwestern cars as there isn’t much left of mine in those areas both left and right . Anybody have a lead or source for some
patch panels , or whole inner fenders ?
Appreciate your time !
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 27-August-2023 at 5:16AM
Almost all of the 1972-1979 mid sized Fords have inner fenders that can swap with yours. So there are a lot of choices to look for. I think the only differences will be minor small hole locations etc. You can get the splash shields from main parts sources, plus the clips.
spriegel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spriegel Quote  Post ReplyReply Direct Link To This Post Posted: 27-August-2023 at 5:53AM
I purchased new fender splash guards from Detroit Muscle Technologies.
They fit my Gran Torino perfectly and came with new clips.
Thanks,
Fairview, PA
'1973 Ford Gran Torino
Post Options Post Options   Thanks (0) Thanks(0)   Quote pyntre Quote  Post ReplyReply Direct Link To This Post Posted: 27-August-2023 at 6:30AM
Yes I purchased the splash guards from them too . Problem is there isn’t any steel left where they are supposed to mount , hence the need for steel patches , or full inner fenderwells .
I’m going to have the motor out in a year or so , so will tackle that fabrication or fix when I can stand in the engine compartment with an unobstructed view of it all !!
1973gts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 27-August-2023 at 2:47PM
I purchased two wheel houses from Desert Valley Auto Parts, they had a lot of surface rust but we're solid otherwise. Not sure where you are at but you could check with them on a price and see if shipping cost would be prohibitive or not.
Dave - 1973 GTS N code
Gold73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gold73 Quote  Post ReplyReply Direct Link To This Post Posted: 29-August-2023 at 7:28AM
I think I have a pair of rust free ones I can sell you. Where you located?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gold73 Quote  Post ReplyReply Direct Link To This Post Posted: 29-August-2023 at 7:30AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote pyntre Quote  Post ReplyReply Direct Link To This Post Posted: 29-August-2023 at 6:22PM
I’m in Minnesota,
55082
Where are you located?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gold73 Quote  Post ReplyReply Direct Link To This Post Posted: 29-August-2023 at 11:32PM
Kansas
Post Options Post Options   Thanks (0) Thanks(0)   Quote pyntre Quote  Post ReplyReply Direct Link To This Post Posted: 30-August-2023 at 3:36AM
Wonder if the inner fender can be removed and replaced without doing anything to the fender itself ( loosening) ?
I replaced the inner fenders on my 69 Chevelle without touching the actual fender , but that’s a completely different animal
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gold73 Quote  Post ReplyReply Direct Link To This Post Posted: 30-August-2023 at 7:07AM
I think they can.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pyntre Quote  Post ReplyReply Direct Link To This Post Posted: 30-August-2023 at 9:25AM
Got a few pictures you could send , what would you want for them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gold73 Quote  Post ReplyReply Direct Link To This Post Posted: 30-August-2023 at 10:42AM
I sent you a private message.
This page was generated in 0.112 seconds.
