1975 Mercury Headers |
Author | ||
pyntre ![]() Member ![]() Joined: 29-March-2007 Location: United States Status: Offline Points: 170 |
![]() ![]() ![]() ![]() ![]() Posted: 06-August-2022 at 4:29AM |
Just got word back from FPA , they have never built headers for a 351m / Fmx car . Didn’t seem like much interest as I got a one line response from them .
I see Hooker quit building the 6125 HKR too . So….. I sure can’t justify a performance 400 build in this chassis with cast iron exhaust manifolds. Maybe I will put an LS motor in it , that seems to be about the only platform being supported by the aftermarket . |
72FordGTS ![]() Admin Group ![]() ![]() GTS.org Admin Joined: 06-September-2005 Location: Ontario, Canada Status: Offline Points: 5449 |
I have the 6125s and they are good. Maybe try to find some old stock or used ones. Otherwise another option is Sanderson Shorties. No one has tried them but I think the Mustang set might work.
72 RS 351 ![]() Senior Member ![]() ![]() Joined: 04-September-2014 Location: Knoxville TN Status: Offline Points: 2449 |
What engine parts do you have now, and what are the goals and budget? A 351M or 400 have limitations that are tougher than other engines. The 351C is kind of popular but most things are geared towards milder combinations and stock trans, rpm's, carb intakes and stock accessories. It takes some thought to work around the limitations. Late model engines will drop right in, any Ford, the LS, even the later Fords(Coyote 5.0 etc). But installing an operating system might be a big project on its own.
Oh at worst case scenario I will have a set of headers made ,
As far as goals , not after a big horse monster by any means , I already have a few of those , I just figured if I am going to go to the trouble of rebuilding the 208,000 mile engine that’s in the car , I might as well make it worth the time and trouble ! The 150 horse power smog plugged anchor that it came with can barely get out of its own way anymore , if it ever could! So maybe 350 horse - 400 ft lb , that’s not asking too much out of a modern cam , intake , ignition and exhaust I wouldn’t think ! Nothing exotic , it’s a 4200 lb couch with a hood that could seat 30 people !!
Ah, that's a reasonable and IMO feasible goal. The 351M is the same as a 400 besides the crank and rods. You can easily rebuild the engine with a 400 crank and rods, raise the compression enough to gain efficiency. Vince can tell you how he built a nice 400 that will definitely move far better than the stock stuff. It would be best to acquire closed chamber heads like the Australian 2V versions, then it can be less likely to ping or need too much retarding of the timing. The right cam(a custom cam will) does allow for regular gas if you keep the compression under about 9.7:1, open chamber heads likely would have to have notably less compression in all cases. That kind of build with stock crank and rods, block, OEM heads, should make 400lbsft of torque at streetable rpm levels. The intake and carb etc, it matters, the exhaust manifolds, headers would be great but the stock manifolds wouldn't kill it completely.
It’ll be a 400 , just picked up a 82k mile
400 out of a 79 Lincoln .
So a 400 +.20 - .30. Might buy a set of bare aluminum heads and load it up with Valves from Tim Meyer ,his pistons too , already have a hydraulic roller cam for it . Figure labor on these iron heads I may be half way to aluminum anyway . Just really bums me out how Holley and a few other conglomerate corporations have bought all the little companies up and then discontinue production on half the parts , what’s the use ??? Yeah so 350 /400 - 400/ 450 hp /tq would be just fine !! |
Great, and good find for the low mileage 400. I think I'd stick with the cast iron heads and limit the rpm's since it's a 400 and the headers are not to be found. I've priced both ways for a long while, and I'm going to do the 4V heads on my complete 351 truck, while choosing the TFS for my other one, also 351C with similar headers and cam, intake etc. The aluminum heads will end up being way over $2k no matter what, while the cast iron might be in the $1200 or so range. I know that nobody is close to me, but maybe one day someone will be able to buy my 400 block and crank, plus finished rods and pistons(polished and balanced with TRW .030 over). I began a 400 project in the late 80's, and the machine shop finally went under when the father died. They couldn't find my crank, so I later bought another 400 just for the crank which is still stock. This block was finished basically, .030 over with screw in freeze plugs, plus 4-bolt main caps. It's been stored in my garage since I got it back, rods/pistons inside in a box. I won't be building one for sure, but somebody could appreciate them.
Trying to find a 400 block or crank these days takes some time and patience and a willingness to potentially drive a long way to get one !! You aren’t shipping 400 blocks or parts these days!!
Where are you located ?
lynchster ![]() Senior Member ![]() ![]() Joined: 07-January-2006 Location: Pennsylvania Status: Offline Points: 2127 |
As I understand it that's easy to get. That 400 would love a set of 4V heads and make better use of them. The do make spacers to adapt 351C intakes to those. If my 351CJ gets hurt I might do a "400CJ" build. Just because.
Rockatansky ![]() Senior Member ![]() Joined: 30-July-2010 Location: On The Road Status: Offline Points: 5848 |
you should be able to fall on your
![]() try to grab a set of Tim Meyer's pistons before they run out of stock again if they haven't already https://www.tmeyerinc.com/product/piston-set-ford-400/ |
handsofstone ![]() Senior Member ![]() Joined: 13-April-2018 Location: Northeast Status: Offline Points: 3828 |
what's the regular Competition header part number? Holley / Hooker just recently discontinued a lot of numbers and clearanced them out cheap so resellers will be advertising them, keep your eyes peeled. too bad you missed the deals |
