  New Posts New Posts RSS Feed - 1975 XR-7 Driveshaft.
brodyajm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brodyajm Quote  Post ReplyReply Direct Link To This Post Topic: 1975 XR-7 Driveshaft.
    Posted: 13-July-2025 at 9:45AM
Hello,
I hauled the 351M out of my ‘75 Cougar XR-7
with an FMX and am curious as to whether
or not I need to get it shortened to properly
mate to my 460.
I have established this far that I need to find
some mounts for a 72-76 Thunderbird which
is no biggie.
Thank you for your time!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 13-July-2025 at 2:12PM
Those two engines use big block transmissions, plus if it's the same one, then it won't need a different drive shaft. The engine mounts might be the hard parts to find, you need them for a 429/460 in the mid sized 72-79 Fords.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 13-July-2025 at 4:10PM
I second what Don said.  The Big Block motor mounts were very hard to find, but I am not sure if anyone is making them now.  T-Bird mounts should work if you can find them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brodyajm Quote  Post ReplyReply Direct Link To This Post Posted: 13-July-2025 at 9:51PM
Yeah, they are a needle in a haystack.
The reason I said “no biggie” is I know a guy that I sold the 429
out of a ‘72 Thunderbird parts car to and am asking him if I can
snag the mounts as he plans on putting that in a truck.
This page was generated in 0.165 seconds.
