  New Posts New Posts RSS Feed - 1977 LTD II Horns
1977 LTD II Horns
69fasbak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 69fasbak Quote  Post ReplyReply Direct Link To This Post Topic: 1977 LTD II Horns
    Posted: 25-November-2015 at 1:17PM
Does anyone have a pic of the horn placement in a LTD II ? I am missing one horn and the other is inoperable. I have checked and I am getting power to the one horn that is hidden but l located an empty terminal and just assume a horn goes there.
1989 Mustang 5.0 Convertible
1977 Ford LTD II
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2015 at 1:06AM
I'll go look some time to day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2015 at 2:21AM
located behind the over flow tank. Only one horn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2015 at 5:17AM
Originally posted by fordpower fordpower wrote:
Only one horn.
that blows
stanman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stanman Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2015 at 11:30AM
I think dual horns were an option but they used the same harness for single horn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2015 at 11:47AM
You should be able to add a second one. Get 2 low-tones and sound like a train!
Ronnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnell Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2015 at 2:18PM
I just got a 78 ltd II sport and was trying to decode the door tag
Could someone help
COLOR-9D
DSO-22
BODY-65D
TRIM-HE
SCH.DATE-0313
AXLE-1
TRANS-X
A/C-A
Thanks for any help
Ronnell
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 27-November-2015 at 1:45AM
Or get an air horn like mine and sound like a boat.
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 27-November-2015 at 3:40AM
There is a picture below of the factory original location of the dual horn option.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 27-November-2015 at 5:36AM
The harness is a simple add on that plugs right into the existing single horn plug.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 69fasbak Quote  Post ReplyReply Direct Link To This Post Posted: 28-November-2015 at 9:42AM
Thanks every one. My car has a harness with a plug that is vacant. and it is outside the fender beside the coolant reservoir.
1977 Ford LTD II
