  New Posts New Posts RSS Feed - 1978 302
1978 302
weaverT1971 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote weaverT1971 Quote  Post ReplyReply Direct Link To This Post Topic: 1978 302
    Posted: 13-August-2014 at 1:50PM
Soooo, I just got done dropping the starter to find out if my 302 in 71 Torino is original or not and it seems it's not. It looks like it's a 302 out of a 78 Lincoln and that means it's a dog of 135HP. Weird thing is that it does not feel like a 135 HP engine at all. The engine has been painted Ford blue and it looks fairly fresh so maybe it was rebuilt, it doesn't sound like it has a bigger cam in it, it does have a Edelbrock performer intake with a Holley 650 on it, no headers but fresh Flowmasters. Besides that it looks like it's stock? I can stand on the brake and seriously spin the tires until smoke is behind me and have no problems at all chirping the tires even though the Torino is heavy. So, I'm wondering my plan was just to get a 302- crate or 351 for it next year but would I by better off going with a top end kit? Edelbrock makes one for like $1600 but I'm wondering if the bottom end would hold up. Or are those kits a waste of money?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 14-August-2014 at 1:10PM
it sounds like you're saying it runs pretty good, surprising well for what it should be...
why mess with it at all?
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 14-August-2014 at 1:21PM
Our 140 hp 1973 302 didn't feel like a dog stock, and it was in a wagon...
Post Options Post Options   Thanks (0) Thanks(0)   Quote weaverT1971 Quote  Post ReplyReply Direct Link To This Post Posted: 15-August-2014 at 12:34AM
Yes, it runs very well. I get a little oil on the top of the manifold but besides that no smoking or anything like that....but I want to get 300hp out of this motor and keep it street able. I had a local shop who builds race engine tell me they can take it, rebuild it, put some go fast goodies on it and get that for me for 3,000. But from what I've read I may be able to get that with just bolt on's like new heads, intake, cam...True or not?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 15-August-2014 at 12:39AM
true
Post Options Post Options   Thanks (0) Thanks(0)   Quote weaverT1971 Quote  Post ReplyReply Direct Link To This Post Posted: 15-August-2014 at 1:13AM
true
Nice, next question. Are those kits worth it, I've heard people say that the cam selections are very good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 15-August-2014 at 1:46AM
Get an stock roller 5.0, install mildly reworked Explorer GT40P heads, roller 1.6 rockers and a good cam. 375 hp at the flywheel. There is a fresh article in one of the periodicals that I am following on this exact build. Cheap, bulletproof, reliable and will bolt right in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 15-August-2014 at 1:48AM
That, with some other small mods, is what I am installing in Stripper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2014 at 4:17AM
Exactly what I was going to suggest. Hell find an Explorer with the 5.0 and just swap it in! Or just a mid 80's - mid 90's Mustang... DONE!
3 things to remember swapping in a late model roller motor...
1. GT40P heads require special headers as the plugs sit straight out not angled. That's why the explorer has those funky looking headers. The amount of difference a DRIVER car will feel...not enough to matter, just get a Mustang GT 5.0 with the GT40 heads, should come with the factory shorty style headers that fit with no issues in the 72-79 cars(not sure on the 68-71 cars)
2 and 3. Ensure you have the balancer AND the flywheel from the roller motor! They are balanced differently than the early/non-roller motors and even if they will fit and bolt up, they will vibrate, shake, rattle and eventually break(BADLY)!
Also get the emission tube bolts that go on the back of the heads. Match the bolt size and buy 2 bolts same size and pitch as short as you can get them. Might have to cut them shorter, use some HIGH TEMP RTV on the threads, tighten them down GOOD and forget about them!
Want to go 1 step further?
Reach in each exhaust port and grind down the emissions hump!
VERY EASY to do, you can see these restrictive pieces and feel th hole that feeds the egr tubes we just sealed off above. Once ground smooth, you COULD suff the hole with some JBWeld or not, no issues either way.
Throw a Holley 600 4BBL on an alum intake and POW you'll love it!
Edited by Regul8r - 16-August-2014 at 4:20AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2014 at 4:32AM
Or cut the ends off the emissions air tube manifold and install them backward as a block-off plate. A little ultra copper and bolt them on. These holes are usually DIRTY from all the "clean" air pumped thru them. I broke a chaser tap off in mine trying to clean it up enough to put a bolt in.
Edited by Big Bird - 16-August-2014 at 4:33AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote weaverT1971 Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2014 at 6:48AM
Nah.....I think I'm just gonna go with the edelbrock top end kit. Way less fuss then finding a goos gt engine that hasn't been beat on, at least with my engine I know what I' starting with
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2014 at 7:37AM
what parts are included in the kit? heads,cam,manifold, carb,???
Post Options Post Options   Thanks (0) Thanks(0)   Quote weaverT1971 Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2014 at 9:47AM
Aluminum heads, cam and lifters, timing chain, performer intake and all the gaskets and bolts....Although I've always wanted to put a modern engine in a muscle car. The only thing that I hesitate on is the fact that it has a computer and all that stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote weaverT1971 Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2014 at 9:48AM
And the heads come assembled and ready to go, you only need rocker arms if you don't use the stock ones and pushrods.
Post Options Post Options   Thanks (0) Thanks(0)   Quote weaverT1971 Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2014 at 10:11AM
Can you point me to that article please.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2014 at 10:44AM
On the stock roller motors, any 302/5.0 87-up passenger car wise that ISN'T a GT motor will have flat-top pistons and E6 heads. These are a little "funny" when it comes to valve clearance. In stock form, you can put a ford E303 cam in with stock ratio rockers, and that's about as big as is safe to go. Aftermarket cams, stay UNDER .500 lift. If you swap the heads to the E7 or GT-40 heads, you NEED to change the pistons as the E6 seats the valves higher in the head and the E7 will hit the pistons at much less lift.
Post Options Post Options   Thanks (0) Thanks(0)   Quote weaverT1971 Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2014 at 1:49PM
Can someone put up some links for swapping a 5.0 into either a mustang or a torino? Ive seen a lot on the net about this being a very common swap and very easy in mustangs but for some reason I cant find a step by step? Anyone?
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2014 at 2:06PM
I have found one: Click Here to see it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2014 at 2:11PM
Here is another one: Click Here to see it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2014 at 2:17PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2014 at 2:21PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2014 at 2:29PM
This next article is about a guy who installed one into his '66 F-100: Click Here to see it.
Edited by dave302 - 16-August-2014 at 2:29PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2014 at 2:40PM
Here is another article on the engine swap subject: Click Here to see it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2014 at 2:43PM
I'll get that article for you on the bolt-ons for a 5.0 HO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2014 at 2:51PM
Here is an article where they had installed one into an '83 Bronco II: Click Here to see it.
Edited by dave302 - 16-August-2014 at 2:52PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2014 at 3:01PM
Here is another article about the engine swap subject: Click Here to see it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2014 at 3:06PM
Here is a good article about choosing which 5.0 to install: Click Here to see it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2014 at 3:09PM
Here is another good article about the engine swap: Click Here to see it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2014 at 3:14PM
Here is another good article about the engine swap subject: Click Here to see it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2014 at 5:00PM
I am curious as to why we are talking about needing info for an engine swap?
You are talking about swapping a 302 with a 302.
Nothing major, just all the 71 stuff needs to be put on the new motor.
The oil pick up tube, oil pan, pullies, brackets, accessories, dizzy, 4bbl intake and carb.
Keep the newer 5.0 balancer and flywheel.
Simple motor exchange same as if you were just pulling and re-installing the 302 you currently have.
Your motor mounts work, your exhaust works, everything else works too.
And I agree, look for the Mustang GT with the GT40 heads.
They accept different rockers (1.7) and work with a lot of the aftermarket add on options better!
Edited by Regul8r - 16-August-2014 at 5:02PM
This page was generated in 0.098 seconds.
