  New Posts New Posts RSS Feed - 300 hp?
300 hp?
colonelsandersman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote colonelsandersman Quote  Post ReplyReply Direct Link To This Post Topic: 300 hp?
    Posted: 16-January-2012 at 4:10PM
What can i minimally do to my stock 1973 gran Torino with 351 windsor to bring at least 300 hp (at the wheels) I know it's a big and expensive jump but if anyone has any cheap short cuts I'd appreciate it
ilyes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ilyes Quote  Post ReplyReply Direct Link To This Post Posted: 17-January-2012 at 1:05AM
Aluminum heads, intake, carb, headers, cam, recurve ignition. A set of gear would help a lot too.
I'd start with a gear change, it's fairly cheap and offers good result
Post Options Post Options   Thanks (0) Thanks(0)   Quote colonelsandersman Quote  Post ReplyReply Direct Link To This Post Posted: 17-January-2012 at 5:49AM
New high flow aluminum heads are pricey, can't get the power I want with just a new intake and carb, exhaust and cam?
Blueoval76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blueoval76 Quote  Post ReplyReply Direct Link To This Post Posted: 17-January-2012 at 11:18AM
Not unless you port the heads. The heads are the biggest limiter when it comes to SBF performance. You have to run a matched combo otherwise it will be pointless and you wont be very happy. In order to get 300 at the wheels you are gonna need about 400hp at the crank and that wont happen with stock heads. It will happen with a set of aluminums and the correct carb, and cam for the combo. Wink
03 Bonneville some mods
