  New Posts New Posts RSS Feed - 302 vs 351C vs 351w
302 vs 351C vs 351w
302ford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 302ford Quote  Post ReplyReply Direct Link To This Post Posted: 29-July-2011 at 7:24PM
only difference between the 302 and 351w is deck height(which results in wider intake spacing as well) 8.2" vs 9.48/9.5". and wikipedia says only a 25lb dry weight difference between the 2
79 LTD II 408/TKO/3.7's
11.78 117.3mph. drag radials
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 29-July-2011 at 11:56PM
lots of internal differences, main & rod bearings, crank to cam center(timing set), rod length, oil pump drive 1/4" vs 5/16"
and the oil pan hangs lower on the 351W due to the longer stroke, so the engine needs more crossmember clearance than a 302
This page was generated in 0.137 seconds.
