  New Posts New Posts RSS Feed - 302
302
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: 302
    Posted: 12-October-2015 at 12:55PM
Is there anything special about a 302 crank.When I bought the car 5+ yr. ago the owner made a point to state it had a ford 302 crank.He was so adamant about it having a ford crank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 12-October-2015 at 1:19PM
around 1985? Ford changed the factory imbalance factor from 28.x oz to 50 oz
both the harmonic balancer & the flex / flywheel needs to match the crank
only thing I can think of, maybe he found out the hard way Ouch
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 13-October-2015 at 12:22AM
All I know is he said if you rebuild that motor,that's a real ford crank.It's even written on it 302 ford.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 13-October-2015 at 6:53AM
not like Ford didn't make 183 gajillion of them, good to know I guess
FWIW you can get an offshore POS that is not indexed accurately from one throw to the next and has out of spec diameters & taper right out of the box
there is a lot to be said for OEM quality
Edited by Rockatansky - 13-October-2015 at 7:06AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 13-October-2015 at 8:59AM
A 4340 forged steel Ford 5.0 crankshaft will take about anything you can throw at it. Not expensive ($250-$400 on sale) and well worth it for a solid base. Stay away from the cheapo stuff, as saving a couple of hundred bucks may well cost you several thousand in broken parts and labor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 13-October-2015 at 9:59AM
Its a 2m early model with two piece rear seal. As far as I can tell most guys on a mustang thread I looked at said it was stronger than a 5.0 just have to grind down the lip for rear seal change damper and flywheel etc.   I will put motor back in car as is.Its a 74 falcon 30 over flat top pistons with roller heads.
This page was generated in 0.152 seconds.
