  New Posts New Posts RSS Feed - 351-4v??
351-4v??
hamilton7711 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamilton7711 Quote  Post ReplyReply Direct Link To This Post Topic: 351-4v??
    Posted: 01-August-2023 at 12:37PM
Is a 351 4 V considered a Cobra jet engine?
78FordLtd2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 78FordLtd2 Quote  Post ReplyReply Direct Link To This Post Posted: 01-August-2023 at 4:15PM
It depends if it is a 1971 351-4v or not. The 351 Cobra Jet was only available in 1971. After 1971 Ford dropped the "Cobra Jet" name and referred to it as just the Cleveland in either 2v or 4v versions. Essentially the same engine as 1971 but detuned...like everything else, but it had the same heads, cam and exhaust. The valve timing was retarded by 4* along with lower compression ratios after 1971. There was little point in calling it a Cobra Jet after 1971.
The 1971 Boss 351 was marketed as the 351 HO for 1972. Again, same engine but detuned for emissions and then it too was gone by 1973. And then by 1975, the Cleveland was turned into the Modified and was no longer a "performance" engine. However, in some advertising literature, the 351M was marketed as "the new Cleveland" but it was by no means the same.
kychevyguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 02-August-2023 at 1:02AM
The sibling of the Torino was the Montego and I have some different info from my Montego database. My 73 Montego was a CJ. But my understanding that 73 was the last year for the Q code cobra jet engine in the Torino/ Montego. The Q code 351 was the 4V CJ engine. Also, they only made 1120 Cobra Jets in 73, of which 197 were 4 speeds. For 1973, the H code 351 was the 2V engine. Also, my understanding that all of this info was independent from the Windsor and Cleveland designations as I heard that the Windsors were 2Vs but the Cleveland could be either a 2V or a 4V.
In 1972, FoMoCo made 1052 of the Q code Cobra Jet engines, with 205 being 4 speeds. They did 3416 examples of the H code 351 2V.
A couple of weeks ago, I picked up a 1971 Cougar and in the beginning of my research with the 71 model years is that there were four different engine codes for the 351 for that year. I am finding that there were two 2V engines and two 4V engines. The M code 351 was the 4V Cleveland engine (what I have in my Cougar) and the Q code 351 was the 4V Cobra Jet engine.
Clear as mud now?
JT, USAF Ret./Architect
1971 Ford F100 "Lizzy"
1971 Cougar XR7 "Kitty"
1984 Chevy Silverado "Sylvia"
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamilton7711 Quote  Post ReplyReply Direct Link To This Post Posted: 02-August-2023 at 1:42AM
This engine is in a 72 GTSS. Not sure what code. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 02-August-2023 at 5:41AM
It will be the fifth digit in your VIN.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 78FordLtd2 Quote  Post ReplyReply Direct Link To This Post Posted: 02-August-2023 at 4:12PM
Yes, you atr correct and thanks for making the info a bit more clear. From the info that I have, Mercury did market the Q code 4bbl version as a Cobra Jet in the Montego and likely the Cougar as well after 1971. Even though the Q code was available until 1974, I was never completely sure if it was still dubbed the Cobra Jet or not and with increasing pressures from insurance companies and govt agencies, etc, etc, dropping the name completely but still keep the engine, even though it was de-tuned, seemed to make the most sense.
Yhe H code 351 2v does not distinguish which engine it would have been installed as there was a 50-50 chance that either the Windsor or the Cleveland would have been installed. The only way to tell would be to look under the hood as they both carried the same code and had the same power output. It was the same for the truck line as well.
Edited by 78FordLtd2 - 02-August-2023 at 4:23PM
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 03-August-2023 at 11:17AM
another way to tell I have been told was after70 till 73 a real one has 4 bolt main both have or all three have the large main cap but only cobra jet was 4 bolt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 04-August-2023 at 11:55AM
The actual engine parts and details, the name, all became vague and random for 1972 and 73. The Fed mandates forced the lower compression in all engines, so the heads couldn't be closed chamber regardless of names or number of "bars" etc. The four bolt mains are trivial because the blocks were all identical(any four bolt main cap can be installed on any two bolt Cleveland block).
So use the Cobra Jet name if you like it for any model, it's just the name. The real meat is the compression(closed chambers or not), and level of heads built. You can do anything to any of the heads, though it's very expensive now(used to be $300 for the works in the early 80's).
FYI, another trivia detail, all Boss 351's and the 351 HO called for six quarts of oil. But they had the identical oil pan as all Cleveland's of that body style, the dip stick is believed to be marked one quart higher. The higher rpm can use the oil, but it better have a windage tray and preferably a higher end pan anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 04-August-2023 at 1:48PM
This article explains the differences for the 351Cs in detail:
For 1972 for Torino it was either a H-Code 351-2V (Cleveland or Windsor) or Q-Code 351C-4V, which was a CJ. Both were low compression regular gas engines. The 1970-71 Torino only used the M-Code 351-4V which was a high compression engine that use premium fuel but not a Cobra Jet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 04-August-2023 at 1:59PM
And, to confuse things more.....
The M-code engine for 1969 was a 351w-4v. That’s what my ‘69 project is
Dfox
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 04-August-2023 at 2:49PM
Dfox
LOL, do you need an intake for that? I built a 351W for my 1986 Crown Vic with a 69 intake that might be a match for that. The engine ran well but the cam lost a lobe after about six months. I expect it was a cam bearing installed wrong, starving a couple of lobes of oil. I then bought a used 1988 Mustang GT engine and made it EFI, which was better than the Holley carb 351W.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 04-August-2023 at 4:06PM
Dfox
My 71 Cougar that I just picked up is a M-code 351C-4v. Crazy! I also thought all Windsors came with 2V only?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 04-August-2023 at 4:13PM
You following all of this Hamilton?
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamilton7711 Quote  Post ReplyReply Direct Link To This Post Posted: 05-August-2023 at 12:59AM
Yes but it’s a lot to digest!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 05-August-2023 at 2:35AM
It may be, this is the best place for helpful information though. There are a lot of knowledgeable and cool guys in here that are always ready to help. I have even purchased impossible to find parts from others in here.
What is the fifth digit in your vin?
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamilton7711 Quote  Post ReplyReply Direct Link To This Post Posted: 05-August-2023 at 3:04AM
Don’t have a car yet. Just trying to get educated from the experts like you. I appreciate all your persistence and help. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 05-August-2023 at 6:32AM
No problem. When you do find one, post info on this forum, and please provide some pics (even if it is not a looker.) We all started someplace.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamilton7711 Quote  Post ReplyReply Direct Link To This Post Posted: 05-August-2023 at 6:36AM
Believe me it will be a looker! I have just sold all my corvettes which were a 61, 2000, 2005, 2009, 2017 and a 2019. I owned  a 73 GTSS in college and just have the itch to get another one.
Post Options Post Options   Thanks (1) Thanks(1)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 05-August-2023 at 6:40AM
Dfox
That’s because yours is ‘71.  Mine is ‘69
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 05-August-2023 at 6:43AM
I’d be interested in it— depends on cost, shipping cost.....
Dave Fox
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 05-August-2023 at 8:40AM
Dave Fox
Don, if Dave is not interested in it, I might be.
This page was generated in 0.093 seconds.
