  New Posts New Posts RSS Feed - 351C and 400 weight
351C and 400 weight
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Topic: 351C and 400 weight
    Posted: 29-August-2011 at 7:58AM
Does anyone know the weight of an all cast iron 351C? What would the weight be of an all cast iron 400?
Thanks
picon3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote picon3 Quote  Post ReplyReply Direct Link To This Post Posted: 29-August-2011 at 9:05AM
Engine Weight and Dimension Comparison
The following numbers come from an early Ford catalog and are for
"typical" engines.  The dimensions include such things as air cleaners, oil
filters, water pump fan, etc., but not bellhousings.
               Engine    Width Length Height Weight
               289-302W  24.0  29.0   27.5   460
               302 Boss  24.5  29.0   28.5   500
               351W      25.0  29.0   29.0   525
               351C      25.5  29.0   29.0   550
               351M-400  26.0  29.0   29.0   575
       Heads
       50.0 lbs  289/302 - complete including rockers
       56.5 lbs  351C 2bbl open chamber - bare
       58.0 lbs  351C 2bbl open chamber - complete except for rockers
       60.0 lbs  351C 4bbl closed chamber - bare
1972 GTS 351CJ-4V black/black
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 29-August-2011 at 2:55PM
Thanks, what I was really looking for was the weight difference between a 351C and a 400. From your data it looks like about 25 lbs.
Edited by 72FordGTS - 29-August-2011 at 2:55PM
occupant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote occupant Quote  Post ReplyReply Direct Link To This Post Posted: 30-August-2011 at 1:28AM
Yup. And about a +3.5lb difference for 4V heads. I imagine intakes/exhaust or headers would make slight differences, too. Either way, a 302 definitely weighs less than either but won't have the grunt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote picon3 Quote  Post ReplyReply Direct Link To This Post Posted: 30-August-2011 at 6:03AM
At least 1/2 of the weight difference between the 351c and the 351m/400 is in the rotating assembly due to counterbalancing the long rods/taller pistons.  P~
