  New Posts New Posts RSS Feed - 351C build up in March 2010 Muscle Car Review mag
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Topic: 351C build up in March 2010 Muscle Car Review mag
    Posted: 20-May-2010 at 8:14PM
good article on a 2 bolt main Cleveland build putting out 466 hp and 471 ft lbs of torque. It is bored .030 over with Edelbrock Performer RPM aluminum heads, Edelbrock Air gap intake, Holley Carb (don't say CFM looks like atleast 750), Keith Black pistons, Comp Cam 0.491 lift intake and 0.476 exhaust with 278 intake duration and 296 exhaust,Comp Cam Roller timing chain, Comp Cams Magnum Roller rockers 1.7:1 ratio,ARP bolts and studs, Melling oil pump and Moroso 7 qt oil pan. that is a nice build and i'm hoping to do something simular with mine for the 73 GTS
Edited by 73 ProStreetTorino - 20-May-2010 at 8:19PM
Fordified V8 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fordified V8 Quote  Post ReplyReply Direct Link To This Post Posted: 29-June-2010 at 2:16PM
Dyno results are in !!!    CLEVELAND ROCKS !!!
508HP @ 5900RPM Horsepower
501HP @ 4700RPM Torque
9.6:1 Compression
393CI 750CFM
70 MACH I "R" code
72 GTS 351CJ
72 TR6
15 F250 Lariat
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 06-July-2010 at 1:40PM
care to give us some details on your buildup?
This page was generated in 0.115 seconds.
